Alternator Engine Load
I have a 2008 Altima 2.5l with a 110 amp alt. When the base hits, the lights dim and the car sort of surges. Under acceleration or steady driving under power, such as up a slight grade, drum beats can be felt like braking action and the RPMs drop in sync with the beat. My first thought was the drop in voltage was affecting the engine. But after an email with Singer alternator, I'm thinking it may be the alternator loading to provide current and physically bogging down the engine.
Does anyone have experience with alternator loading?
Even if I add a second battery, the alternator will load on the drop to 12 volts, won't it?
Do high output alternators put noticeable drag on the engine?
Thanks,
Brian
I seriously doubt one stock alt would be enough to big you down like that. You could be having belt slip when is the last time you changed your belt and tensioner? Also what does your system consist of? it could be possible you are drawing so much power that you are pulling your voltage down to the point of almost shutting the car off and the alt is fighting to keep up Hence the surging and dimming
Sorry it took so long to answer. I can only post early in the morning or late in the evening. I just have a couple of amps, an Orion XTR15001, and a Rockford Fosgate P8004. I think they both put out rated (1500 RMS and 800 RMS) given the proper input voltage. I changed the belt 20k miles ago. I'll look today for any belt dust or slippage indicators.
On a stock 110amp alt you car running lets say 2.3k rms. i feel you are pulling more power then your car can supply and that could be causing the issue but i could be wrong.
Do you have a volt meter in your car if so what volts is it showing wile you are playing your system at 2k rpm's
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
I know exactly what you're talking about. My car has the equipment in my sig and when the bass hits I can kind of feel it bogging down the engine a little bit. Granted mine is a 4 banger and I"m assuming yours is the 2.5L v6, but I have a Mechman 240 amp alt and it does the same thing your stock alt is doing. On songs with a drum like beat it does the same thing as well, it's almost like I can feel it slowing down a tad with the beat. My friend's honda did the same thing when he installed some subs on a 1500 watt amp, he was running stock alt too. My car has done it for as long as I remember and I've never had an issue. With the equipment in sig and the Dc 3.5k at 0.4-.6 ohm voltage doesn't go below 13.0 so I know it ain't that.
THE ANTHRACITE DYC CRUISER
-Fully dipped anthracite grey pt cruiser
-4 skar vvx 12's (version 1)
-Mechman 240 amp alt -Big three in Cadence 1/0
-1 deka intimidator g31 blacktop under the hood
-1 C&D 140ah Batt & 1 C&D 55ah batt in the rear
-Re audio/soundstream mids and highs
-Hifonics Zues 600.4
-DC Audio 3.5k
I appreciate your reply. You have pretty much confirmed my suspicions. And the 2.5l is the 4-cyl... the Nissan 6-cyl is a 3.5l. My lights are dimming too, so I have 2 problems; voltage drop and alternator loading. I think I'll add another battery and a capacitor before I go buying a 500 dollar alternator. I don't listen long at full volume, so I'd hope two batteries would find time to charge. I think a cap would stiffen short drops a bit.
I've read in several forums to get a good quality capacitor. There's several references to the ones in a felt lined box and a volt meter being bad, but no real references to which ones to actually get. I'd be looking at 1F caps... probably two in parallel. What caps might be good quality for the money?
IMO. the amount of money you will be spending a second battery and a good cap should be just about the price of a alt.
Optima yellow top (ok for car audio) 150-200
Rockford Fosgate 1 farad cap (looks kinda cheap to me) 75-107 from sonic electronics
so on the cheap end you can get away with spending about 250.
Here is the better way to do things IMO with out adding a alt
xs power d3400 and xs power d680 OR the xp2000.
the xp2000 is about 250 and the d680 is about 125. and the d3400 is about another 250
really the choice is yours but IF it where me I would just get the alt and do the big 3.
141 on music.
Over 2k RMS you need batteries and h.o. alt. To do it properly.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Adding a high output alternator will worsen the "engine bogging" problem, but improve the voltage drop problem.
Assuming that your system will actually use more than the 110 amp capacity that you currently have, the car will slow down more when the bass hits. More amperage requires more Horsepower, there is no way around that.
We could tell you otherwise in order to try and sell you an alternator, but we would be lying.
  • Who's Online   0 Members, 0 Anonymous, 3129 Guests (See full list)
