Possible Idea to Increase Belt Wrap
Plain and simple, when I shift fast, my serpentine belt slips. It was perfectly fine with the OEM alt and that belt. Obviously my Singer has an overdrive pulley, which is smaller. As a result, less of the pulley is covered by the belt. I want to fix that, and here's what I thought of...
Basically, here's the alternator in its bracket:
Id only like to focus to the pic on the left.
Here's my belt routing:
I have A/C.
Bascially, four bolts connect my alternator bracket to the engine. You can see those 4 point in the first two pictures.
On the first picture that shows the alt's pulley, Id like to add an idler pulley on the lower of the two mounting bolts in order to increase belt wrap.
My confusion is with the OEM idler pulley. It'll have less belt wrap if I add a secondary pulley. Would this be a problem? Would it squeal?
Edit:
Or would you just replace the oem idler with a larger one?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
LMFAO so true
:blush:
Shift slower
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You should be able to add a smooth backside idler pulley to INCREASE the belt wrap on the alternator pulley. That will help the overall performance of the alternator, but you will probably still get a "chirp" from the belt on high RPM gear changes. A larger alternator pulley and/or decoupler pulley would be the only way to fix that, but it would kill the idle output of the Singer alternator.
  • Who's Online   0 Members, 0 Anonymous, 3249 Guests (See full list)
