*SOLVED* *Im happy as balls*CANNOT get wire into my doors...last straw before i'm done....any help? *pictures top of page 4* and first post.
I'm not reading through this bible of a thread, but what I do when I get desperate is run the wires to behind the head unit and connect the factory speaker wire to the speaker wire coming from the amp, connect at the harness.
thats what im going to do .
i love all the ideas but i really believe the door has to come off and even after that, there is no for sure bet simply because i cant reach it under the dash.
im not pulling the dash
And that only works if yourfactory wire can handle the load and it's not amplified. It's also fairly ghetto. If I'm going to spend the time to change everything out I'm changing it all out. You never know what those wires go to or ran next to or into etc. Using power and ground for the head unit is one thing but i do not reuse factory speaker wire at all costs.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i wanna say 100wrms would be ok and skimping by especially with the last part being the ofc12 gauge from HU to amp.
im trying to be optimistic.
Just find a way to replace it bro. If it's my way or taking a door off and drilling a hole. Do it right and leave it like that for the rest of the time you own the car!
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Do you guys all think i can get away with running it from back of heaunit to the amp and use factory wire so its half 18 and half 12?
that may be the only option in th eend...or its bye bye time
I've done it a few times with about 90wrms through it. Sounded really good. just have to make sure you don't have a stock amplifier.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
i do have a stock amp
Shit I completely removed My doors and drilled a hole
Why can't you do that
how hard is it to remove a door? and get it back on properly?
not hard if you have a right angle pneumatic impact. it will be a pain in the ass with a regular socket wrench, but doable.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
i might try a real long extendo clip on my drill bit go under the dash and try to ge the right angle on the grommet to drill through it and come out above the wires and then just run it that way. shot in the dark.
