Kyblack76 Posted January 20, 2014 Report Posted January 20, 2014 This may belong in the SPL section. I dunno. Anyway, im looking into gaining more playable band, and by playabe, i mean LOUD playable, not, Oh, i can hear it playable. I think that happens on here a lot. You get the dude saying, "I can play from 20 to 55. Well, i can to, but im talking with nuts behind it. After speaking with a lot of you, and others that get loud, i was told to either or, open the vent, or shrink the enclosure. My enclosure seems quite peaky. A peak around 37hz. Playable from 25-46 but with balls behind it 28-39. And uber at 31-38. The drop off in the 40's is a fair amount. So, with the port work would require baffle work. So, i went about shrinking the volume with enough cut 2.4's to equal around 1 cube. I screwed them in, remounted the subs, and tested almost a db loss at my peak. Also down was the low lows. 25hz i put up a 50.45 now im down in the 49's at 25hz 37 (as said) was 54.50 now a 54 flat. The 42-44 range is up!, but not anything cool....... so, it seems maybe my band width did stretch a bit, but, not much. I wanted to keep my peaks where they were, just gain more on the outter FREQ's. Suggestions would be tits. Also, i dont really know my specs. TIA Kyle SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
RooTxBeeR Posted January 20, 2014 Report Posted January 20, 2014 In for info, and a free bump!!! On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Kyblack76 Posted January 20, 2014 Author Report Posted January 20, 2014 In for info, and a free bump!!! Thanks. I know, i fucked up on testing. I should have kept things more IDENTICAL, wrote everything down..... All i do know, is my peak (at 36) was a 154.54, and im down i THINK (cant remember) around 3 or 4 tenths. Which, isnt much. My 25hz blast pulled a 150.24, and it was down in more. Around 149.xx i believe. The only gain, (and it was expected) was at and around the 42-44hz mark. But it was only a few tenths i think.. Im not sure if any of it was worth it. Sucks to, it took pulling 2 subs, and a wasted saturday. Oh well, thats the game i guess. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
kirill007 Posted January 20, 2014 Report Posted January 20, 2014 You won't gain any avereged dB's if you shrink the enclosure without adding more power. Opening up the port will give you what you want. If you model your enclosure, you can see what will or will not help, usually more port area will give you a louder result. Thinking is the root of all problems... You ALWAYS get what you pay for.
Kyblack76 Posted January 20, 2014 Author Report Posted January 20, 2014 I was trying to stay clear form port re make. For obvious reasons. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted January 20, 2014 Author Report Posted January 20, 2014 I was told if I over shot my volume, I could rise a bit with shrinking the volume. Maybe I'm at where I'm at with this build. Which isn't horrible. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
