justin0943 Posted January 21, 2014 Report Posted January 21, 2014 if you formate the drive it will earase everything you need to get a oem disk of whatever version you have just stick the disk in and just read update you can download xp oem disk for free just do that and just give it away or just trash it 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Bump4life Posted January 21, 2014 Report Posted January 21, 2014 ^^ first person i have ever seen quote them selves. i can see you talking to yourself lol Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Tarball Posted January 21, 2014 Report Posted January 21, 2014 I've used GDISK with a few switches and get very good results. DOD has forensic tools that can read a HDD 7 layers deep, So anything less than that and the data is still accessible ( though not by any schmuck), The only true data eratication is to write 1s or 0s to the disk 7 times over (or more) and then physically destroy the platters or the entire disk. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
justin0943 Posted January 21, 2014 Report Posted January 21, 2014 ^^ first person i have ever seen quote them selves. i can see you talking to yourself lol na i didn't see what os he had but then I saw it while I was scolling up and was like fuck so thats the reason I put update on it and all thats what I get for not reading all of it. 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Guest Posted January 21, 2014 Report Posted January 21, 2014 standard "format" wont get rid of the data. you need dban or a similar multi-pass wiping tool.
beaker Posted January 26, 2014 Report Posted January 26, 2014 dban kicks ass. There are a few other tools that will do everything from zero the drive, to write random data to all the platters for 48 hours. As far as SSD drives, its a different animal. SSD's have hardware garbage collection. Basically what that means is when the MFT marks a spot as "empty" it doesn't actually empty that spot right away, it would be too slow to do that on a platter drive, so when new data is written, the old gets written over because it was marked as "empty". This doesn't work too well on an SSD, because the longer you power a cell, the lower the life span of that cell. So to prolong the drive, the firmware on the drive will go through and check the MFT (Master File Table) against the drive and write zeros to those sectors or cells to power them down and extend the life of the drive. This makes forensics on an SSD difficult because as soon as the drive is powered on it starts cleaning up cells.
