Dd1 not picking up amp distortion
Skax
Speaker wires disconnected LPF all way up hpf all way down gain wide open full and not picking up anything .. Heaadunit is 33/35
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
if thats the case it not even getting the 40 hz signal
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
I guess I need like a full rundown on how to do it all I feel like I'm just fuckin something up
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
slow down
Are you checking the HU ? or going through the amp (which i hate)
and what freq are you using ? 40hz or 1k?
im trying to set the gain on the mids and highs amp using 1k hz and I was getting the max undistorted volume through the amp also
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
slow down
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Are you getting the 1kHz detect light coming on while you're testing it? And is 33/35 the max undistorted headunit volume that you got after testing with both the 1k and 40hz notes? You could also try swapping out batteries in the DD1, I know mine was tripping out when it had a low battery once
I have the red lead into the right output like the thing beside the rcas
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   0 Members, 0 Anonymous, 636 Guests (See full list)
