sorry noob question but please reply
It idles at 14 something and 12.6 car off but my voltage drops to about 10.8 11 with strong bass notes
is this when you first start up and play songs because some veichle has a 20sec delay for the alt
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Sorry it took so long but I let the truck sit and my voltage is at 11.8
batt a little weak but seems good
2 sundown sd-2 d4
flex tech
box design by Joe X
If your battery voltage is below 12.3- 12.4 the battery is practically considered dead.
yeah ur batt should never sit under 12.3 resting man..new stronger deep cycle battery ..check your fuse between ur battery and amp as well
2004 Chevy Trailblazer LT
Walled- 10.5 cubes net tuned 33Hz
2-15 inch AA Team subs D2
Americanbass- 750.1
1 yellowtop under the hood , 4 c&d 88ah batteries in rear
mechman-270
pioneer headunit-4200UB
4 soundqubed supertweeters
phoenix gold 2 channel
back up camera
stinger volt meter
22 years old and still have alot to learn..lets get it
I run the duralast platinum from auto zone. Even got 10% off by just asking. So like 134 bucks for a good agm battery. A battery made a big improvement in holding voltage steady.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
  • Who's Online   1 Member, 0 Anonymous, 1218 Guests (See full list)
