I smell some burning!!! HELPP!!
xxtony1105
Okay so here is the story...
I was cruising down the road with my system full tilt and suddenly I started to smell something burning, like a metal type of smell. I though that maybe I was clipping and turned it down until I got home. When I got home I played it again with volume at max and played till that smell came back. Then I shut it down and checked the temp of the woofers by touching the cone/dust cap. They weren't even warm or anything like that so Idk what it could be. If you need to know I have 2 C2 Audio Threatcon-2 12s on a Soundstream TX1.2600D and all of my gains were set by using the SMD-DD1
Thanks for the help here.
EDIT: I should also mention I have 1 run of 1/0 and I believe its CCA. It's from Knu Konceptz. Could this be overheating?
That could be some excess glue burning off finally
pull em and check em out visually
i know what your talking about. It starts off with the smell of burning glue then switches rapidly to the metal like smell.
your amp could be getting hot
2004 Chevy Trailblazer LT
Walled- 10.5 cubes net tuned 33Hz
2-15 inch AA Team subs D2
Americanbass- 750.1
1 yellowtop under the hood , 4 c&d 88ah batteries in rear
mechman-270
pioneer headunit-4200UB
4 soundqubed supertweeters
phoenix gold 2 channel
back up camera
stinger volt meter
22 years old and still have alot to learn..lets get it
Americanbass- 750.1
mechman-270
back up camera
stinger volt meter
Um turn it down
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 2855 Guests (See full list)
