SterTheDer Posted February 2, 2014 Report Posted February 2, 2014 Common misconceptions about Capacitors, and the math to back them up. The single BIGGEST misconception about audio. "The rule of thumb is to put in 1 Farad of capacitance for every 1,000 watts RMS of total system power... The larger the cap, the faster it gets ready for the amp's next big hit."~ Crutchfield.com Before I deconstruct this myth, lets cover the basics. What is a capacitor? Simply put, a capacitor is an electrical device that stores a voltage potential. It stores power in the same way that a cup holds water. In this analogy, Capacitor voltage = Cup water level and Capacitance = volume of container. For the capacitor to do anything, it requires a voltage drop. For water to be used, the water level in the cup must be lowered. The water (Volume) will flow from the point of highest elevation to the lowest. Current flows from the point of highest Voltage. Whatever has the highest voltage in an electrical system will supply the rest of the system. (Water flows downhill!) This means that it is IMPOSSIBLE for ANY NUMBER of batteries to be of ANY USE if your current draw does not exceed the limits of your alternator. The cars alternator will supply ALL the current/power at about 14.8v (The alternator has the highest voltage at this point) Voltage drops below 14.8v when the current draw is greater than the alternator output. How much this voltage drops is dependent upon the alternator and current draw. Voltage will continue to drop until it reaches 12.8volts. The cars battery/ies will supply all the necessary current below 12.8v (Here, the alternator voltage output drops to the level of the batteries, and the batteries will supply the current needed) If the current draw continues, the batteries will eventually be depleted, as indicated by a voltage below 11 volts. (the chemical reaction in the batteries is exhausted, and the batteries can no longer support the load) Voltage of 10.8v or lower indicates that you have completely drained all the reserve capacity of your battery. (Probably should turn it down now and let things recharge) Now that we have this understood (you took notes right?); Consider this scenario: Stock electrical. Aftermarket audio system where the amp draws more current than the alternator can supply. System drops voltage from 14.8 volts to 12.8v. After some time the voltage drops to 10.8v. MATH: E = (1/2)* C * V^2 Joules(Watt-seconds) = (1/2) * Capacitance (Farads) * Voltage^2 1 farad capacitor: E= (1/2) * 1 * 14.8^2 E = ~109.52 Joules of energy. This is how many Watt-Seconds the 1farad capacitor can supply from 14.8 volts down to 0 volts. to figure out how much power would be supplied to the system, we calculate the difference in stored power across our voltage drop. 1 Farad capacitor: 14.8v = ~109.52 Joules. <- Vehicle charging voltage. The ideal maximum voltage your car will see. 12.8v = ~81.92 Joules <- Battery voltage. The maximum voltage your batteries can supply. 10.8v = ~58.32 Joules <- Critical battery voltage. This low of a drop indicates depleted batteries. Now, we calculate the voltage drop and receive the amount of power the capacitor contributed to the system! (Drop from 14.8v -12.8 ) 27.6 watt-seconds. (Drop from 12.8v-10.8 ) 23.6 watt-seconds. (Drop from 14.8-10.8 ) 51.2 watt-seconds. This means that if you added a 1 farad capacitor to this car audio system, the cap would supply a whopping 27.6 WATTS for 1 second before the batteries became the current source. WOW! a 10 farad cap would supply 276 Watts.(meh..) a 100 farad cap would supply 2,760 watts.(that is a lot of power eh?) It seems like a 10 farad capacitor or greater might be a worthy investment after all? JUST WAIT. This power, Joules, Is a measure of watts/second. This means that over time the cap really flounders. that same 100 farad cap would only supply 1,380 watts for two seconds (not bad) 690 watts for 4 seconds... (eh) 345 watts for 8 seconds... (um) 172 watts for 16 seconds... (boo) and less than 80 watts for 30 seconds To really be effective with a capacitor, we need to get stupid ridiculous. a mammoth 1,000 farad capacitor would supply 27,600 watts... for one second. (Holy smokes!) that 1,000 farad cap would only supply 13,800 watts for two seconds (not bad) 6,900 watts for 4 seconds... 3,450 watts for 8 seconds... 1,725 watts for 16 seconds... Hopefully you see how incredibly useless a 1 farad capacitor would be in this situation? Now, back to the misconception, 1 farad for 1000 RMS... how much power does 1000watts (RMS) take? Heh, in an ideal world with 100% efficient amplifiers, 1000 watts would take exactly 1000watts of power. Based on our calculations, we would need approximately 37farads to supply this metaphorical amp for one single second... But wait a minute! Did someone say “What about the alternator?!?” yes, we must discus that! The alternator, as stated, supplies the power above 12.8volts. In most cars, the alternator produces somewhere around 100amps, give or take. (My 97 Camry has a 40/80 amp alternator) This seems like a lot, but it is needed to power the car itself, the lights, electronics, and engine. Budget that the car will take at least half of your alternators capacity, in my case ~40 amps. This leaves you with ~40 amps for aftermarket amplifiers, or (14.8*40 + 592 watts) so, I can easily deliver around 600 watts to my system, ANYTHING over this amount will cause my voltage to drop, eventually to 12.8v. The capacitor will help supply current to whatever is above the limit of the alternator. In my case, if I had for example a 700w amplifier, I would need to supply 100w from somewhere to keep my system above 12.8v. In this case a 10farad capacitor would work quite well! It would fill in the gap for 2.7 seconds. When playing music, this would fit perfectly. When we get into large systems, 1Kw, 2400rms, 4000w systems... a capacitor just isn’t feasible. Therefor I can say that the myth of 1f per 1kw is bullshit and false!( can you imagine.. Steve Mead.. with stock alt,stock battery, and a 30farad cap? LOL!) Now, a departure into the opposite side, those arguing that “While using a cap much larger than recommended will not damage an audio system, it is not recommended because of the unnecessary strain it puts on the vehicles electrical system.” -SonicElectroinix The myth that capacitors add additional strain to your system. In theory, yes.. yes they do. But really.. look again at the math! It takes roughly the same power to charge a cap as it does to drain it, meaning that the electrical load for charging that 1 farad capacitor from 12.8 volts to 14.8 takes a whopping 27.6 WATTS for 1 second WOW! a 10 farad cap would take 276 Watts.( 276w/14.8v =~ 20 amps) We can clearly see that the capacitor doesn’t take much to charge, meaning that if your system is close to the alternators capabilities (As in the 700rms system example) that a 10farad capacitor wouldn’t hinder the system much! (It would charge back up in between peak current draw, IE with the beat of the music) To take this further, it becomes apparent that if you have a system with a large cap bank and small charging system, say my setup with 40 amps and 1000 farads, it would take me (27,600/14.8 = 1,864 amps. 1864/40 = ~46 seconds) If I drained my cap to battery voltage, and then shut off my amps completely, it would take 46 seconds to charge my capacitors. You can see that a large cap can be harmful! In conclusion, a capacitor can be a wonderful way to extract additional performance out of a system that is drawing slightly more power than your alternator can handle, but only when the capacitor has around 5-10 farads. Unfortunately the price range for such a capacitor puts it out of the range of consideration because much more viable options are available. A better option instead of investing in a capacitor is to upgrade your main battery. Straight up replace your lead-acid battery with a performance AGM car audio battery. Why would you do that when the alternator does all the work above 12.8 anyway? The high performance battery does not draw as much current as the lead acid does, meaning less strain on the alternator and more power available to your amplifiers. In addition, if/when the voltage drops to 12.8v the high performance battery will supply more current than its Lead acid counterpart. Your new battery will also offer better cold weather performance, will look wicked cool, and will recharge faster. For those who have, or are planning, a really large system, and are planning on spending several hundred on batteries.. consider upgrading your alternator instead/ in addition. You must increase your current generating capabilities in order to power your setup. An alternator also weighs much less than batteries, and doesn’t need to charge. I hope you have learned something from reading this article, please let me know what you think! (PS, i am still figuring things out on SMD forums, If this post belongs somewhere else i would be happy to move it) (EDIT: i was able to add this same post under Electrical-Battery-Alternator by following around some links, but i am unable to acces "Equipment" (Site says You do not have permission to view this forum.) that leads to the topic "Electrical-battery-Alternator" thus i am unsure of how i would return to that part of the forum... i appoligise if this has caused any problems... :/ (double edit! How would i go about deleting this post? I would consider this post to be a "double post" that can be deleted)
afrakes Posted February 2, 2014 Report Posted February 2, 2014 Wow. Made it through the 1st couple paragraphs and am already putting this in my bookmarks. I'm at work, will read the whole thing later. But seriously, awesome post dude. Vehicle: 2014 GMC Sierra 2500HD WT Head Unit: Pioneer DEH- Mids/Highs: Focal Integration ISC 165’s (front) Subs/Amps: TBD
ParDeus Posted February 2, 2014 Report Posted February 2, 2014 While not knowing the math, I've been sharing this for years.
SterTheDer Posted February 3, 2014 Author Report Posted February 3, 2014 While not knowing the math, I've been sharing this for years. And i think that this forum,and many of the members here have been doing a great job of this! Keep it up! I know that this information is not new, but in my own quest for knowledge i have spent a signifigant amount of time trying to figure out just why capacitors dont work, and for that matter, what they can and cant do. This post was intended to be a usefull guide for somone who is either looking at using capacitors (They can be quite usufull when USED PROPERLY), or is recieving conflicting ideas from manufactures or the media or the internet. This was made to show people why the myths are a myth, and what that 5 farad cap they have laying around is or is not acutally doing
Raptorman Posted February 3, 2014 Report Posted February 3, 2014 Awesome post. Knew they were shitty but it's cool to know the math! Thank you sir. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
n8ball2013 Posted February 3, 2014 Report Posted February 3, 2014 This is already in the correct section. No need for two THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
