Running my amp at lower impedance than it's meant for?
chrisw.
Well since I probably won't see you again, bye.
Krakin's Home Dipole Project
Why won't you see me again?
Because it doesn't seem like this forum is a place that you're too fond of. You basically scoffed at it a couple messages above. If it's not for you, it's not for you. Your attitude kind of makes or breaks the experience for you.
op
simply put what everyone is saying is that the way you clamped your amps is inaccurate and not a rms wattage measurement but a va (volt amp) measurement. unless you had it on a resistive load (resistor bank not speaker) and used the right tools and made sure that your results where right before or with very little clipping then your results could be way off. know one is saying they aren't underrated amps just that by such a huge amount its just not believable.
the ad-1 uses a resistive load and works in ways that a simple clamp test cant even touch. that's a piece of high end equipment that will eventually change car audio for the better by setting a standard testing for all companies imo.
will the amp work at a lower then recommended impedence? yes
is it risky? yes
can it catch on fire? yes
should you do it? no
why? because if your asking the question you don't understand the risk that you are taking and its always better safe then sorry.
everyone else, im sure we can agree that he agreed it wont be a good idea and he is going to just get a bigger amp instead. however your point that his clamp method wasn't accurate had no proved facts behind it until krakins post with the vid. that being said it most likely could have been avoided If it was better explained rather then just repeated several times.
now since all the answers are in one place can we just let this thread die?
maybe it can be locked.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
No.. it must live on! 5 moar pages !!!!!111oneone---.. _
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
How about we forget about the clamp test BS and examine this example of the way new comers are treated. Go back and reread the thread and ask yourself if I deserved the treatment I got. By a moderator no less. You can say I was argumentative all you want but you can't quote any examples. You all don't seem to mind. Something is wrong with that. But I won't judge the entire board by the actions of a few.
Still Living in the 90's
MTX Thunder 2300x
MTX Thunder 2150x
MTX Thunder 275x
MTX Thunder 1500dx <---still searching
It happens. Sometimes all the kids on the playground dont play nice, but you never make any friends if you run and tell the teacher.
No one has treated you like crazy bad racist ill murder your mom just because youre purple..
Its a forum. People can say just about w.e
But instead of replying to every comment. Whether its postove negative or w.e just do a little research and reading. And appreciate the time and effort that has gone into trying to help you. And accept that ppl get frustrated afyer answering the same question 100 times by 5 different ppl.
In the end do what you want. Read. Learn. Move on.
Setup:
Xs D3400/ Xs XP3000
I just re read your responses and N8's responses. N8 said he could guess which amp you had. Your response was to snap back instantly with ,"your guess is wrong". So can you see how that may come off as abrasive? Everything from there was reaction to that sort of comment, I think.
Can I see how that could come off as abrasive? N8 was being a dick, period. I was standing up for my self and now you're protecting his behavior. Like I said, something's wrong here.
MTX Thunder 2300x
MTX Thunder 2150x
MTX Thunder 275x
Who's running to the teacher? Or is that just an analogy that doesn't apply here? I'm just standing up for myself. I have no emotion towards this. It more so fascinating to me on some level. I'll keep responding and keep standing up for myself as long as the thread is still open.
MTX Thunder 2300x
MTX Thunder 2150x
MTX Thunder 275x
  • Who's Online   0 Members, 0 Anonymous, 341 Guests (See full list)
