n8ball2013 Posted May 17, 2014 Report Posted May 17, 2014 Who are these people youre referring too? THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
MrSkippyJ Posted May 17, 2014 Report Posted May 17, 2014 so its rated 300@4ohm @ 12.5 volts...that would be 600@2ohm raise the voltage to 14.4 and you get more power...not sure what the big fuss is. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
chrisw. Posted May 17, 2014 Author Report Posted May 17, 2014 The amp is not supposed to be stable under 4 ohms mono. Not only have I been running it at 2 ohms mono but I tested it with the old amp vs volts method and got over 900w. The rest is everyone telling me my amp was going to catch fire, my test was a joke, my amp isn't underrated, I'm a noob ect ect The wiz test basically backs up my claims and is consistent with my "inaccurate" test. Also since it didn't blow at 1 ohm it's probably fine all day at 2 ohms. Still Living in the 90's MTX Thunder 2300x MTX Thunder 2150x MTX Thunder 275x MTX Thunder 1500dx <---still searching
n8ball2013 Posted May 17, 2014 Report Posted May 17, 2014 Ok you win. Enjoy your amp THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
mmets Posted May 17, 2014 Report Posted May 17, 2014 well if its not suppose to be stable under 4 and you can run it at 2.......um ok. Man up now and put that mofo at .25 and get the real power then lol http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/Pioneer DEH-80PRSPRV 8MR400-NDY (eight) PRV TW350Ti (6)Sky High 1/0 OFC, 12 gauge and 8 gaugeTM Metalworkz battery terminals 120 sqft HushmatXS Power D3100 (6)Singer 350 Amp Alt Singer 320 (2)American Bass SQL3200 JL Audio JX360/4 Crossfire XS 8K (2) DC Audio XL 15s (6)
chrisw. Posted May 17, 2014 Author Report Posted May 17, 2014 I'm curious what it will do at 1 ohm now. I'm guessing 1100w or so but I don't think I want to push it. I'm happy with 900w at 2 ohms Still Living in the 90's MTX Thunder 2300x MTX Thunder 2150x MTX Thunder 275x MTX Thunder 1500dx <---still searching
MrSkippyJ Posted May 17, 2014 Report Posted May 17, 2014 The amp is not supposed to be stable under 4 ohms mono. Not only have I been running it at 2 ohms mono but I tested it with the old amp vs volts method and got over 900w. The rest is everyone telling me my amp was going to catch fire, my test was a joke, my amp isn't underrated, I'm a noob ect ect The wiz test basically backs up my claims and is consistent with my "inaccurate" test. Also since it didn't blow at 1 ohm it's probably fine all day at 2 ohms. people run amps under what they are stable at all the time. Those amps usually burn up (not actually catch on fire mind you) and they end up buying another amp. None of this should be news or anything people don't understand. The clamp method IS inaccurate, even if it happens to return "correct" results from time to time. There is no way to capture which time is correct and which time isn't. The amp isn't underrated or overrated, it seems to be accurately rated. And there is no rating for 2ohm mono so no matter what number it puts out, you can't compare it to any ratings. But as far as what one would expect from 2 ohm mono it seems to do what is expected...still not sure what you are trying to prove. It protects when it is supposed to, does what the manufacturer claims. What is the point? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
chrisw. Posted May 17, 2014 Author Report Posted May 17, 2014 My issue was wtih you coming in here claiming outrageous numbers out of an amp that is not capable of doing it because you were not testing it correctly. What happens then is it starts to spread. People start spreading rumors about how much power they can do and how its ok to run the amp way below rated impedence and next thing you know its all over the place. See the 45s in the corner of boxes and all the other stuff that have become internet legend. So while I am here to keep the peace so to speak, I am also here to keep misinformation from coming part of the I saw it on the internet it has to be true information. I don't know you to not like you so its not personal. I just don't want to see someone read this thread and think its ok to try that with their amps expecting huge power out of it to watch it turn into a sparkler. Still Living in the 90's MTX Thunder 2300x MTX Thunder 2150x MTX Thunder 275x MTX Thunder 1500dx <---still searching
