I wanna try out some 8's as my main sub set up. I already have one 12 that hits 143 on the TL. But I just wanna see how loud I could get maybe four-six 8's. Think it would be louder than 143db? The amp would be a Brutus 1606d. What do you think?
do eight 8s and a RF T20001bd.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Just remember you've just to work with your ohms there, 4 Dual 4 ohms 8" subs, you're looking around 0.5 ohms if not lower due to you RE ohms = 0.41 ohms. There's many wiring patterns you can go with. But run somewhat near what it's rated, cause I don't want you to fire a amp. 8" subs are great for the deepest of midbass, and they'll move some air, but don't think you'll be hitting high dB #'s on lower Freq.'s. Your test Freq is going to be very high. 55-60 Hz. What 8's did you have in mind.
I have this dream of this underground culture in mind, coming to life through the Audio that I build, Deep Perfection.YUKON'S SITEhttp://www.cardomain.com/ride/2397609
not true, I have done a 150 with 6 aa 8's @ 40hz.
did a 144 legal with 6 re 8's.
and 4 dual 4ohm woofs is 2 ohm OR .5 ohm
with your power i would go with 6 ascendant audio 8's
Now it depends on what car you have to determine if this is a good set-up for you or not.
Ray I'm not downing anyone here, seemly meet it's hard to get a high number with 8's at lower Hz. But a 150dB run I got to give you some props on that one, really so @ 40Hz. I never wire anything in series, unless I have too.
ended up doing a 51 at 53hz.
played 30hz great but its focus was at 40-50hz without a doubt..
rock was amazing in the car.
I was thinking 4 dual 2ohm 8's so I could wire them to 1ohm. With the Bxi 1606d that would be 1600watts. I didn't really have any in mind, that's why I was asking for opinions on which ones to use. I have an 02 Silverado single cab. I'm wanting to use the 8's, cause with the 12 I lost all the leg room on the passenger side. So when my wife, daughter, and I all go somewhere....my wife is all cramped in the middle and there's barely any room for the car seat.  Kinda just an idea to see if I would like it better. How much would 6 AA 8's cost? How could I wire 6 subs to 1ohm?
Ok, nevermind about the wiring issue. I found the thread on wiring diagrams. I can wire 6 dual 4ohm subs in series/parallel to get 1.3ohms. Which is close enough for me. I don't wanna go under 1ohm with the amp and end up blowing it.
  • Who's Online   0 Members, 0 Anonymous, 390 Guests (See full list)
