One Subwoofer Not Responding to Lows.
Exscathe
The subs when I had them playing individually were perfect yes, also I realize that I dont need a filter for a test tone, that is common sense, the LPRC filter was inline with the RCA's as in it was soldered into the RCA's, and I was playing the 25 Hz test tone because the filter was set to 30 Hz so I only got the really low end of anything, so to test out the drivers, 25 Hz test tone.
I would redo the individual testing again just to see if something has changed since the last test. Also I would remove the filter when tested together or set it at much higher frequency than your test tone (like 60Hz for example). At a single frequency test tone two drivers can act differently due to manufacturing tolerances or due to incomplete break in of one of them.
make a wiring digram in paint and post a pic of it here. the new can visually see the wiring you did.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
That RCA LPRC filter is not adjustable, have to make a new one, and I will be using different RCA's and a different amp. I am going to wire the subs to a 1 ohm load tomorrow to see if that makes a difference, I really dont see anything else being a problem. Also on a 25 Hz test tone, both drivers slammed the house to bits and each driver was only seeing around 150 watts each, it was ridiculous.
ok go back and look at kranny's post (post #14) and compare that diagram to yours. kranny's is the correct way. not sure one the wiring you did but I think that is the issue. looks like it could maybe work but I would just rewire to the diagram kranny posted and I can just about gurentee it will fix the issue.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Your out of phase man
Should be like this for 4 ohm load
FE7C89E5-C3A4-4F09-BEE7-AF3CE4A8DFCF_zps
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 1427 Guests (See full list)
