box terminal help
Mspell
Trying to figure out what the best way is to do terminals on my box. I want to be able to change ohm loads without having to take speaker out.
1 Sub dual 4ohms
so you want to change from 8Ω to 2Ω?
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
Just hook up wires to screw with some bolts and washers
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
Brass bolts and washers or copper if u want to spend the money. With a little bit of silcone on both sides to help seal it up. Do 4 bolts per sub then you never have to do any wiring inside the box once they are mounted.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Here are some binding post options:
http://www.parts-express.com/cat/binding-posts/1506
I am using Part # 091-1245 on my box, but only have one set because I have my ohm load wired on the inside of the box.
  • Who's Online   0 Members, 0 Anonymous, 3326 Guests (See full list)
