Road noise issue help, already dampened
So as the title reads, I am having issues with the rear lower c-pillars in my truck. This is where the cab vents are, behind the plastic trim panel that also houses the rear seat belt retractors. There were some type of deflectors from the factory that came into the cab from the vents... but impeded the ability to really build a solid box back there, so I removed them. My question is... with the back wall being double-layered with sound deadener, and knowing I can't cover these vents, what should I try? I have polyfill back there tucked into the corners right now, but that didn't seem to do crap.
All four doors are deadened and "sealed" as much as can be. I have also read the sounddeadenershowdown.com wbesite almost to its entirety. Should I use a more dense foam block or expanding foam setup back there? Anybody have crew cab trucks that may be running into the same issue?
My impression is that these vents balance humidity and pressure so that my cab doesn't get moldy and such. So covering them most likely isn't an option.
As always, I appreciate any help from yous guys
Did you deaden over the vents. My truck is a 98 and windows up its coffin quiet
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Man I didn't. I thought there would be a good reason to leave them open (something to "balance" moisture, pressure, etc). But you haven't had any side effects of sealing yours off eh? I may just give it a try.
No.not really doors shut a little heavier is all
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
All they do is release the pressure when you close the door.
Like Kylar said, fill em in and be done with it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I have an extra bottle of expanding foam laying around and thought about that. I also have some spare Fat Mat as well, I think I'll try that first and go with the expanding foam if I'm not satisfied.
This was just was I was looking for, Thanks for the help guys
