sbg Posted February 21, 2014 Report Posted February 21, 2014 I got a box right now for my hdc312s that is a temp box. Tuning way to high and a bit small. 4cuft. Tuned to 42hz . 87" port area and 22" port per foot. Just a box I got from a friend to get me by until I build new. I see some people doing port plugs, to lower tuning. I think I could use this to help me out. Was thinking of inverting my subs and doing a plug to lower my tuning to 35hz. I have never done this before and not even sure it works? I have a port deflecter in the back of the box. Do you take the plug all the way back to that? And is it going to be worth my time to do this? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Triticum Agricolam Posted February 21, 2014 Report Posted February 21, 2014 I would think you have more than enough port area, so loosing some to a port plug should be no problem. You need your plugs to go all the way to the ends of the port. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
SnowDrifter Posted February 21, 2014 Report Posted February 21, 2014 I shim mine all the time. Just make a big MDF block (stack sheets, don't need to be glued together) that goes from the front to the back of the port. Secure it in place with bolts or something. Oh... And the tighter the fit the better ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
sbg Posted February 21, 2014 Author Report Posted February 21, 2014 I have this think it will work? It's the right H x W that I need just a few inches to long. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted February 21, 2014 Author Report Posted February 21, 2014 Spray it with some clear so it don't fall apart? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted February 21, 2014 Author Report Posted February 21, 2014 Well shit. Just spent 3 min to make it. Will test after I take my soon to school. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
DubNDodge Posted February 21, 2014 Report Posted February 21, 2014 Hope it works!! If you do use mdf/wood. Make the width a TAD smaller than the needed. Wrap the bish in box carpeting. Gives for a nice snug fit '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
sbg Posted February 21, 2014 Author Report Posted February 21, 2014 Yep works good, sounds a lot cleaner now to. it's hard to see because my eyelashs are moving lol. The plug is a crazy tight fit right now. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
agf144 Posted February 21, 2014 Report Posted February 21, 2014 Spray it with some clear so it don't fall apart? Don't spray it with spray paint! That makes Styrofoam melt. Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
sbg Posted February 21, 2014 Author Report Posted February 21, 2014 Spray it with some clear so it don't fall apart?Don't spray it with spray paint! That makes Styrofoam melt. Lol stupid me. Good thing I didn't. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
