Soundqubed
Deuces
I'm probably going to buy two soundqubed HDS312 subwoofers and was wondering what is a good amplifier to power these I'm going to wire them down to 1 ohm they're 1200 watt rms, looking for an amplifier preferably under $200 please any suggestions are welcome
Goodluck with a budget of 200$.
What does your electrical look like?
Even though those subs are cheap, powering them won't be. Guaranteed.
Look for a SQ2200 to power them, between that and crescendo are your two budget amplifers. in the 2k range.
You WILL need to do the big 3 if you haven't already. Upgraded stock/front battery, and something in the rear as well.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
What he said. 200 for a 2k amp is impossible unless you eather get super lucky or buy used. IMO save up and buy a 2k but you will need to think of the electrical you will need to run it. Or you can under power then now and buy a sq 1200. Or just get the hds2000 line
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
On that budget you really need to think about what your trying to accomplish. It's not as simple as slapping a big powerful amp into a car with no electrical upgrades. Without spending a few hundred dollars on beefing up your electrical u can slap a big expensive amp in and fry it due to low voltage issues and you won't even see the power it's rated at because it needs to be supplied the power it needs to make the power it's rated for.
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
Also, what box are you putting these in?
If you read the reviews on the sub and expect you can just drop these sub in a prefab box and get the results you want. You are extremely mistake.
These subs need more cu ft then the average 12.
Well I know boss is bad... I have a good battery in the car now and can easily get a second, I'm running 1 gauge wire and have an NVX cap right now, and if a good 2k amp isint goin to happen for $200 whats the price I'm going to be looking at?
$400-500.
define good battery..what kind?
1 gauge? or 1/0 gauge? or 0 gauge?
dude... boss makes some 5K amps for less than 200.00, all you need to do is supply the lightning.
and a flux capacitor.
  • Who's Online   0 Members, 0 Anonymous, 3301 Guests (See full list)
