Tweeter Placment in Pickup(TA) ?
ImaNoob
I agree with cablguy. I run my tweets in the A pillar also. Seems to be the best location in a pick up.
truthsayer
Ok, I just kinda skimmed through your build.Ill go through the rest later. when you had the tweets in the pillars you said it was great for staging etc, not to harsh with them facing you/pass. Then you changed them . So overall what way did you like better ? As far as tweets go. Did you build the pillars or buy those ?
Both ways sounded bad ass with great stage and image ... We went with the mids for placement (competition). Just a lot more details within the stage and image.
We are setting up my younger son's truck up with the tweeters in the A-pillars like my original setup ... Just a little more eye level and more on-axis ... Mainly cause his mids are a lot higher than the Chevy doors had. He's driving a 88 Ford single cab so that should give a nice stage and image with plenty of width for a single cab truck ...
What would you recomend for a mid (Id like to stick with rockford) ? With out taking up to much spaceI think it would be easier for me, to build a pod on the dash. < not sure i wana go this route but thinking my options through..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
The tweeters can be manipulated before final installation ... but those door midbass drivers took some trial and error work ...
If you plan to set one up ... this is how I would go with your truck ... I would wait on midrange drivers until you have a total feel for your system ...
this setup worked extremely well with time alignment ...
Can a complete idiot pull off a pillars ? I haven't done glass work before..Nor do i think i trust myself..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
As difficult as glass work sounds, its really not hard. Its more time consuming than anything. Use some CA glue and a few pieces of small mdf to get your general shape and a good mounting location or just use some foam you get at Michaels and then get some fleece or old shirts or any kind of fabric really and stretch over your shape and mount it to the back side of the panel. Then add some resin, some glass, some more resin and make sure there arent any air bubbles. Then just let it cure and sand away. Then get some filler to fill in the small holes and to give a little more shape. Then sand some more and paint.
  • Who's Online   0 Members, 0 Anonymous, 1541 Guests (See full list)
