Double side tape, mounting hardware that comes with them, what kind of tweeters? Never hard of spray adhering tweeters.
From their site
One Speaker Kit contains:
  • (2) 7" diameter Second Skin back wave canceling discs
*Super Glue required to adhere speaker pad properly
But spray adhesive could work well too I imagine. Just make sure to spray both surfaces and let it tack up first.
Edited by Trill
Minnesota! Y U NO GET WARM!
From their site
Oh well hell I must have not seen that part of it. Thank you for the help I was looking at the site a little while ago as well. Super glue then it is I was just not sure.
No problem. Like I said in my edit in my original post, the spray adhesive should work too if you have some on hand. I'd probably try that over superglue because superglue gets hard and brittle. But I'm no pro and have no experience with that item so its up to you. Can't go wrong following the manufacturer's recommendations :)
Let us know how you like then. I have some weird resonance in the doors occasionally but I haven't bought them yet because I'm planning on glassing some door pods so I figured I should wait and see how the new set up sounds. But if they work well I might just get some anyway.
