My issue is NOT which HID company/type/color ... I've got my own stuff going on, I have a kbcarstuff Volt + and DDM kit available ...
What I'm thinking is using a projector properly in my headlight assembly... Surprisingly no horrible scatter w/ the housing in my Camry
The projector I'm interested in is the Morimoto Matchbox 2.0 Intended for fog lights I feel it might be the easiest install into my stock assembly
Here is a list of what I'm working w/:
HIDs:
kbcarstuff Volt + (xenondepot) 35w kit
DDM tuning 55w kit
wiring harness/relay
Vehicle:
2003 Toyota Camry
stock headlight assembly
What everything looks like:
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
nada? thoughts?? pre-made kits that I could use instead??
Unfortunately, you wont get much help here when it comes to anything headlight related :( You should look at HIDplanet.com though.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
True. I'll have to get back on there. I'll post results if I go on with mod
There is one person who does alot of retro fit work. Popwarhomie is his name he's not on here much though.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Thanks n8...
If you are still interested in doing this its very easy with the matchbox and the mini h1 projectors. Bake apart headlights, mount projector using supplied hardware and adapter plate, Wire hid's install headlights with lenses off, align projectors horizontally and vertically, put lenses back on reinstall headlights. Shouldn't take more than 4-5 hours for everything if no painting is involved. There are a ton of walkthroughs on hidplanet like another poster suggested that can guide you right through this.Also thanks for wanting to install hid's the correct way!!
Use the mini h1 projectors, the part that goes where your stock bulb would go is smaller so you wont have to cut as much or at all. But like bluethunder said, pull headlights apart put projectors and shroud in with supplied hardware, plenty of videos on YouTube showing how to do so. Best of luck.
  • Who's Online   1 Member, 0 Anonymous, 1585 Guests (See full list)
