Mounting amps on roof/ grounding
Mark-E-Mark
Im starting a desing for my new system. I have a painted picture, now gotta paint it! The design includes an amp mount on my roof. I own a small car. 2000 chevy cavalier. I have big plans with the option of some major equipment. But first I have to figure out the grounding of the amps. I will have 4 XS XP950's in the trunk. Unsure right now if they will be far back in the trunk or up close to the back seat area. Basically I want to know if running ground wire up the side panel to the roof to a bus bar will work for ground. I mean I follow the general rule on grounding less then certain inches. This is why im stumped. I will have plenty of 1/0 awg stinger.
Thanks
Pioneer DEH-P5800MP
4-Kenwood 6.5's
2-Powerbass 6x9's
2-Autotek Street Machine 3200.1's
1-Autotek Street Machine 1400.4
2-12'' Lanzar Optidrives 1232d
1-XS Power 950 AGM Batt
1/0 AWG Stinger for Big 3
DB Link 4 AWG ran
There are bigger issues when mounting g amps to the roof than just the grounda. Gonna take some welding to pull off and a complete restructure of alot of things.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I know that. I need the question answered. Im cutting, welding, inserting braces, mounting a board, making bus bars. I just simply need to know how the grounding will work. Just didn't want to get into details for a simple question. I have more questions but they don't have anything to do with this question. Any help would be appreciated.
Pioneer DEH-P5800MP
4-Kenwood 6.5's
2-Powerbass 6x9's
DB Link 4 AWG ran
Eh.. Id do some research on your amps heatsink design.
In one of the builds on here.. a while ago.. a guy had 4 Rockford T4ks. One was mounted on the roof. Thats the same amp that failed out of the four. He got it repaired, same thing.. failed again.
He looked into more info, and saw that those series amps weren't designed to dissipate heat in his type of installation.
Heat rises.. and when it has to go through the whole board.. that worries me.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Thank you. Just had this wild design and just want to see if it will work. I will do some research. I am not set on these amps. They were more my entry level amps. Im looking into some major ones. Soundstream Trantula ones are sick. Kicker 3001bd I might be able to grab for about 450 or so. But I will definitely research the amps I choose. As far as grounding incase I make out okay?
Pioneer DEH-P5800MP
4-Kenwood 6.5's
2-Powerbass 6x9's
DB Link 4 AWG ran
Also could fans work, like under the board blowing onto amps? For heat? Im open to all ideas. Trunk area will be completely full. Backseat has to close.
Pioneer DEH-P5800MP
4-Kenwood 6.5's
2-Powerbass 6x9's
DB Link 4 AWG ran
For the record the new Soundstream Tarantula amps are legit.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
If you were to mount the normally top side up onto the roof it should be ok. Sort of like a hanging shelf.. with room on top for air flow. Plus you want to reduce any chance for vibration. .
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
How you like that XXX?
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
Nothing sound stream makes is really "legit" just another middle to low end amp
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 865 Guests (See full list)
