F me, I need answers please...
ParDeus
Ok, so I have 4ga ofc, alt does 122 at idle, 147 at 2000rpm. Battery is a G34 Deka.
So I'm tearing my car apart to trade in to the dealership today, and I find that my main fuse is 40a! I thought it was a 100a!
I've had a MB Quartz 1500.1 at .5ohm, a Mmats d300hc at 2ohm, and a Mmats 3000.05 at 1ohm, all on this exact electrical.
With 2 12's in a trunk fence (lol) I metered in the mid 140's.
So 500w at most?
Gain set with scope and DD1 at -5db.
Deck is an Kenwood x995.
WHAT. THE. FUCK.
Explanations anyone?
Thanks
Bad fuse? Or you just aren't drawing many amps? seems a bit odd to me as well. maybe somebody will chime in with a more intelligent answer.
CARS
14 Sierra crew cab daily, Small build coming one of these days
69 C-10 fleetside in many pieces, won't be done till the end of time
Last car '12 Focus with build log
http://www.stevemeadedesigns.com/board/topic/165619-2012-focus-btl-15-crescendo-sundown-audio-control/
Ehh, either the fuse is crap (I doubt) or my buddy's TermLab is junk.
There is no fucking way it would score like that on such low power. It was a shit box with mad air leaks. Other people thought it was loud, I however, was deeply unimpressed.
It was not an anl fuse, but a shitty agm glass tube fuse.
I guess it might lend a little credence to how efficient a Mmats amp is, but God, they're not physics defying efficient.
Fuses are thermal not electrical like a circuit breaker.
A 40A fuse isn't going to blow at 41A, it will continue to conduct, you'll just get a bit more voltage drop, the higher the current.
Up until the fuse gets too hot and melts.
Fuses are more for sudden large surges of current, like a hard short circuit to ground.
My guess is that you had higher voltage drop across the fuse, but enough for everything to function..........and I bet that thing was HOTTT :o
Any heat damage around the fuse holder or anything?
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
No heat damage, the damn thing looks new actually.
My voltmeter said I dropped to 13.4ish at worst...
I have the same thing going on.
I run a brz2400 at 1 ohm should pull over 200 amps, I have a 100 amp fuse on the power line and it won't pop. I haven't had my setup on the meter but I have been told my setup has to be high 40s. Its kinda crazy I don't drop past 13.3-13.5 full tilt also....
I also have 4ga wire, stock alt is 150 amp and my battery is stock 60 something AH.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Magic is the only logical explanation.
Lol
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 582 Guests (See full list)
