ParDeus Posted March 13, 2014 Author Report Posted March 13, 2014 I believe the purplesyrup guy with the wine barrel had the same issue. He couldn't pop a 100a fuse with a Mmats 4000.1. Odd...
Skullz Posted March 13, 2014 Report Posted March 13, 2014 Might be that the amps have enough capacitance or buffer to prevent a sudden draw on your electrical system causing the fuse to pop. That's just merely a guess but would need someone with much more knowledge than myself to explain. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Wicks Posted March 13, 2014 Report Posted March 13, 2014 The T15K is the only amplifier, that I know of, that actually "stores" energy by means of a large internal capacitance bank of ultracapacitors / supercaps. The capacitance in all other amplifiers is mainly for filtering, not energy storage. Here's a spec sheet on an ANL fuse: http://www.cooperindustries.com/content/dam/public/bussmann/Electrical/Resources/product-datasheets-a/Bus_Ele_DS_2024_ANL.pdf Check out the current curves. The fuses will take ~2X their current rating for a continuous 100 seconds before melting. Fuses are meant to protect you from very large current spikes (shorts to ground), not necessary just "smaller" increases in current. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
ImaNoob Posted March 14, 2014 Report Posted March 14, 2014 So does running a smaller fuse actually hurt voltage or only when it heats up ? My amps recommend 100 amp fuses and i run 80s..what i had ..Whats the downside of running smaller fuses ? 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
Wicks Posted March 14, 2014 Report Posted March 14, 2014 So does running a smaller fuse actually hurt voltage or only when it heats up ? My amps recommend 100 amp fuses and i run 80s..what i had ..Whats the downside of running smaller fuses ? Yes and yes. Exactly like running smaller power wire from the front to back, it will induce more voltage drop. A fuse is just a chuck of copper, same as your power wire. When your conductor heats up, the resistance will increase so more voltage drop. Double edged sword. I doubt you would see any difference in running an 80A fuse. From the above chart, it showed that an 80A fuse would probably run ~160A for 10 seconds until melting. Fuses are thermal so it takes a large current to blow them. If you were to run that 80A fuse at 100A for a matter of hours then it could gradually heat up and eventually melt down but since audio is so dynamic, it has time to cool and therefore it lasts. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
JEFFYBOI Posted March 14, 2014 Report Posted March 14, 2014 There is a lot of different type of fuses. fast acting, time delay, single element fuses and a lot of special fuses made for different applications. like someone said fuses are thermal overload protection only... These fuses are probably time delay, meaning you would have to pull a lot of steady current for a long period of time. If your power is sufficient it will make a huge difference. The fuses are doing there job, if they are not blowing they are happy. 10 years of electrical experience. "Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21 PIONEER DEH-P8400BH 2 CROSSFIRE C5 1700D 2 CROSSFIRE C7 18 HOOD. NSB GROUP48 TRUNK SMS AGM400 DUAL RUNS X SCORP 1/0 OFC 275A SINGER ALT. DYNAMAT XTREME SOUNDSTREAM TA4.280 PIONEER COMPONENTS
