AMM-1 Dyno of MB Quart 1500w amp
Pro7
So my AMM-1 just came in and right away I had to get to using it. I have an MB Quart q1.1500d (a Maxxsonics amp so think hifonics) in my car running off of a D3400 and the 5.7L stock alt (160 amp I think).
So on to RESULTS!
Freq- Dyno'd power @ measured box rise - Measured Power Factor
30hz - 1043W @ 1.6 ohms - 95%
33hz - 1048W @ 2.0 ohms - 83%
34hz - 1032W @ 2.1-2.2 ohms - 79%
36hz - 951W @ 2.5 ohms - 78%
40hz - 607W @ 4.1 ohms - 73%
42hz - 563W @ 5.4 ohms - 74%
44hz - 501W @ 7.4 ohms - 76%
46hz - 445W @ 10.1 ohms - 80%
48hz - 423W @ 9.3 ohms - 96%
50hz - 421W @ 6.8 ohms - 95%
I tried to get voltage drop but the dc volt min/max was only reading max and 0.0 constantly for min :(
I might try again later to get voltage drop but if the min/max doesn't work it's difficult for me to get that number by myself.
Amp Guts Posted ↓↓↓
Conclusion
I know these numbers aren't too important since I couldn't get at what voltage it was at but I had the car running at idle and if I had to guess I would say I dropped to ~13.0V.
This was about what I was expecting from this amp, nothing too impressive but it wasn't wayyyy under rated power. I've been waiting to do this test before getting a new amp and it finally came in! I might do it all again to check the voltage but what do you guys think? I thought the 33hz numbers and 46hz numbers were the most impressive/telling.
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
Yeah it's crazy that it's wired to 1 ohm and rises to ~10 ohms at 46hz. I'm still trying to make sense of all these numbers but isn't the tuning frequency of a box supposed to be shown by a spike in impedance? So does that mean that my box is in reality tuned to 46hz??
In torres it said that this box is tuned to 35hz but I did kerf one outer side of the port but that wouldn't affect tuning that drastically would it?
awesome! looks like you are having some fun! :D
Follow my Tweet (Twitter)
The tuned frequency of a vented enclosure will have a VALLEY, not a peak in the impedance.
In the impedance curve of a vented enclosure there will be two peaks in the impedance, one before the tuned frequency with the second rise coming a few octaves after the resonance frequency. The resonance frequency will have the lowest impedance in between the two peaks.
Edit: Remember that the resonance of an enclosure will change depending on its environment.
Krakin's Home Dipole Project
Ok thanks, I was kinda worried that I somehow screwed up my port to be tuned to 46hz
It would also be cool if you could find the impedance curves at different initial amounts of power (to have a control frequency like 30 hz or 100 hz).
I can try this tomorrow and edit it into the original post, any other things you guys think I should try?
If I can get the dc min/max to work I think I'm gonna check the drop across my run from batt to amp and at amp under load.
  • Who's Online   1 Member, 0 Anonymous, 698 Guests (See full list)
