Is your volt meter calibrated?
I would have to say so, as the Stinger volt meter, and my Pioneer 80prs both indicate the exact same voltages...
Other than that, I have been told I should look into and external voltage regulator... The only problem with that is if I were to take the alternator back out, that would be a nightmare... I didn't take on the task of changing this alternator because it's in a very weird spot so I had the dealership do it... It took them 9...yes 9 hours to change the alt...
The voltage just seems weird to me because if I'm driving, it's at about 13.6, and if I let off the gas as I am driving it goes up to 14.2 every single time
I really appreciate everyone's input on this... Maybe it is just a Ford thing... I'll look into the external regulator and hopefully I won't have to send the Alt back to Nations
Pioneer DEH 80PRS HU
Ascendant Audio SMD 18"
Audioque 3500.1D
XS Power D3100
Rockford T1 components
Rockford P400X4
Do you just have one XS power 3100 as the second battery and that's it? What about your under the hood batt? I would want at least 2 d3100's for the AQ 3500.1 That amp is 4300 rms if you're talking about the one with the dual inputs. I'm running the setup in my sig and I have similar battery power to you and I drop to about 13.2 full tilt at 0.5 ohm on my DC 3.5k. I charge around 14.2.
Yeah I just have the stock battery under the hood and just one D3100 in the back... I had this same exact set up in my 2001 Blazer extreme (minor difference in alts) and was pretty close to keeping it at 14.x volts most of the time... That's why I wanted to figure out why I'm not in this vehicle... The install is brand new, just got done 2 days ago
Audioque 3500.1D
XS Power D3100
Rockford P400X4
I thought there was a trick to having the alt charge higher. Maybe I'm confused with Honds or GM.. But either turn on ur headlights, AC/heat, or defroster. Then look at voltage.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Tuned in for the conclusion, but damn, brand new ride eh? Also, that sub wants gobs more power...
Yeah, I have been looking into the DC 5k...
Audioque 3500.1D
XS Power D3100
Rockford P400X4
Audioque 3500.1D
XS Power D3100
Rockford P400X4
Just as a note if dc power isn't machined into the case I'd be really hesitant to believe they made it. Keep that in mind. I don't know of any company is that they oem for
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
They are... It's the same place I bought my DC 300 amp alt from in my 01 Blazer extreme... Not only that, but it's literally the ONLY alternator I could find to fit oem in the 14 Explorer... Checked everywhere... The alt it good, I'm quite certain of that
Audioque 3500.1D
XS Power D3100
Rockford P400X4
I'm fairly sure they make voltage boosting modulators (? Could be wrong in naming) that will truck it into charging higher.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Ok, so here's an update... After turning my air on, the voltage stays at 14.5 volts... Guess I'll just leave the heat or air on... Haha
Audioque 3500.1D
XS Power D3100
Rockford P400X4
  • Who's Online   0 Members, 0 Anonymous, 4424 Guests (See full list)
