Hello, I have questions regarding the voltage in my vehicle... I have a :
2014 Ford explorer
270XP Alternator (nations starter and alternator) who deals with DC power
Big 3
1 18" Ascendant Audio SMD
Audioque 3500.1D
XS Power D3100 secondary battery
Rockford 400 watt 4 channel
Stinger voltage meter
My question is this... Why is my voltage registering at roughly 13.2-13.6 volts at 1500-2000 rpm... And right around the same (maybe a little less at idle)... I would THINK I have everything I need to get a sufficient 14.4 volts... No?
Thank you very much
Pioneer DEH 80PRS HU
Ascendant Audio SMD 18"
Audioque 3500.1D
XS Power D3100
Rockford T1 components
Rockford P400X4
What's ur starting voltage? If it's above 14.2, then wow.. Did u check ur grounds?
Also, what's the AQ wired to? .5 or 1 ohm. If it's 1/2, then I understand.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Tuned in for the conclusion, but damn, brand new ride eh? Also, that sub wants gobs more power...
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Do you just have one XS power 3100 as the second battery and that's it? What about your under the hood batt? I would want at least 2 d3100's for the AQ 3500.1 That amp is 4300 rms if you're talking about the one with the dual inputs. I'm running the setup in my sig and I have similar battery power to you and I drop to about 13.2 full tilt at 0.5 ohm on my DC 3.5k. I charge around 14.2.
THE ANTHRACITE DYC CRUISER
-Fully dipped anthracite grey pt cruiser
-4 skar vvx 12's (version 1)
-Mechman 240 amp alt -Big three in Cadence 1/0
-1 deka intimidator g31 blacktop under the hood
-1 C&D 140ah Batt & 1 C&D 55ah batt in the rear
-Re audio/soundstream mids and highs
-Hifonics Zues 600.4
-DC Audio 3.5k
Ford like to charge low when hot. My focus like to sit around 13.8 hot.
Try turning on AC, your heater, lights, ect ect. The compete should recognize the increase power draw from that stuff and increase voltage.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Oh, wow.. I misunderstood the question. I thought you were talking about your voltage DROPPING to 13.x when revved up and playing full tilt.
My bad :bad:
But yes.. I agree.. some of the newer fords have odd voltage regulation.
LMFAO so true
:blush:
External is the best way to get past it. You can end up with a battery light and possibly a check engine light from it but I doubt the check engine light.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
This. The only thing is that the alt would have to get sent back to DC Power for them to open up the case and rewire it.. Unless you're handy in that sense.
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 1934 Guests (See full list)
