hankfan79 Posted March 18, 2014 Report Share Posted March 18, 2014 Vehicle: 2012 Toyota Camry (4cyl) Alt 240A Mechman Big 3 Xs Power Battery D3400 It is my understanding that the newer Toyota cars are voltage regulated by the PCM. Therefor, I can't change the fact my system doesn't charge where I want it to. My voltage after idle down is 13.7 When driving around 1700-200rpm the voltage is 14.0 This is with no stereo running. When lights are turned on the voltage drops and then immediately returns to normal. However, when I turn on the rear defrost, it drops to 13.3 and does not raise back up until I turn it off. To me this doesn't sound right. Am I wrong for thinking that? In a perfect world I would like 14.4 or close to it to achieve optimal performance from my amps. 1 Quote Link to comment Share on other sites More sharing options...
Kyblack76 Posted March 18, 2014 Report Share Posted March 18, 2014 (edited) That all seems fine to me....... EDIT- no way in hell youll see 14.4 in that vehicle internally regulated. No way. what you are seeing TO ME, is more than perfectly normal. Edited March 18, 2014 by KyLar96 1 Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
hankfan79 Posted March 18, 2014 Author Report Share Posted March 18, 2014 That all seems fine to me....... EDIT- no way in hell youll see 14.4 in that vehicle internally regulated. No way. what you are seeing TO ME, is more than perfectly normal. 13.3 just seemed a little low for driving at that rpm range. Wish I could figure out how to raise it. Well, without a nagging battery light on (module mod). Quote Link to comment Share on other sites More sharing options...
DubNDodge Posted March 18, 2014 Report Share Posted March 18, 2014 To me that sounds low. Then again. Your car is 11 years newer than mine. I have stock alt and I turn every accessory on and hold the same voltage I started with. which right now is about 14.3-14.5 did you do the big 3? 1 Quote '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
Amart88 Posted March 18, 2014 Report Share Posted March 18, 2014 My old car was PCM controlled. Charged at 12.9v when driving. 13.8 with light turned on. It sucked. Quote My 2005 s10 blazer build. 4 zcon 18's walled. Link to comment Share on other sites More sharing options...
Kyblack76 Posted March 18, 2014 Report Share Posted March 18, 2014 That all seems fine to me....... EDIT- no way in hell youll see 14.4 in that vehicle internally regulated. No way. what you are seeing TO ME, is more than perfectly normal. 13.3 just seemed a little low for driving at that rpm range. Wish I could figure out how to raise it. Well, without a nagging battery light on (module mod). Well, your turn on, may not being met. Its a very new unit. Maybe your rpm isnt turning it on. New platforms are not easy..... Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Kyblack76 Posted March 18, 2014 Report Share Posted March 18, 2014 Makes you wonder why everyone rates their junk at 14.4 huh? not everyone does. Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Amart88 Posted March 18, 2014 Report Share Posted March 18, 2014 I would get an externally regulated setup personally. Only way to 100% beat the PCM. Quote My 2005 s10 blazer build. 4 zcon 18's walled. Link to comment Share on other sites More sharing options...
hankfan79 Posted March 19, 2014 Author Report Share Posted March 19, 2014 I would get an externally regulated setup personally. Only way to 100% beat the PCM. Not willing to do that on such a new car. That and the fact my battery indicator would continuously stay on. Probably void any sort of warranty I have (electrical). That came straight from the folks at Mechman. Why would the rear defrost draw the voltage down to such levels? Even with all factory electrics are turned on..it still comes back to 13.7 just not when the rear defrost is on. This is regardless of RPM. Quote Link to comment Share on other sites More sharing options...
Amart88 Posted March 19, 2014 Report Share Posted March 19, 2014 Because the computer has different voltage setpoints in which it will charge at a different rate. Sometimes its the auto lights, defrost, rpm's accessories and such. Quote My 2005 s10 blazer build. 4 zcon 18's walled. Link to comment Share on other sites More sharing options...
