ESTIMATION NEEDED!
I am planning a tline build for my kicker 12". I'm gonna be using my schools AG shop and possibly some wood from there. My problem is that I need to let my AG teacher know the amount of wood that I'm gonna be using so if anyone could help me with a rough estimate on the amount of square ft I will be needing I'd really REALLY appreciate it. I'll be using 1/2in if that helps anyone. Thanks again to anyone who can help me!
Figure out the dimensions 1st, that'll give you an idea then up it a little bit to make room for mistakes.
I say get 1 sheet of 3/4 in MDF bord and you should have more then enough . May even be able to build 2 boxes incase you mess up lol.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Use atleast 3/4 inch , not 1/2inch.
A full sheet and maybe then some depending on how low it will be tuned and what the layout will be.
I would definitely use 3/4. I think you can get it on a sheet
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
3/4 for sure
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
How much do you know about t-lines? The port on that is gonna be around like 9ish feet or something I think. It will be something like 13 inches tall so rough estimate I'm gonna say 8-10 inches deep and 9-10 feet long. Be conservative and try to draw out a box and get dimensions then you will know how much wood. (Just get two 4x8 sheets or 3/4inch mdf)
Thanks ! Imma plan a few different boxes on paper then hopefully ill have it built within the next few weeks...I can only get into the AG shop an hour a day :/ and plus were on spring break :)
Make a cit sheet first too. Sucks when u run out of wood because u layed ur cuts out improperly. Happened once to me before, had to buy a second sheet just for a square foot cut lol.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
I use sketchup to help with cut sheets. I lay down a 48X96" and start making boxes for your cuts so you can figure out how to get the most out of your sheet of wood.
  • Who's Online   0 Members, 0 Anonymous, 2936 Guests (See full list)
