Benjamin Amparo Posted March 20, 2014 Report Posted March 20, 2014 hey guys hopefully someone can help me out. im going to be buying either the SQ hds212, two of them or 1 hds312. i know cone space is king so obviously two hds212 will be louder but my concern is the size of the box. i heard sq/aq subs require big boxes. i got the dimensions for my trunk, 36(l) x 16 (h) x 24 (d). i know absolutely nothing when it comes to building or designing a box and i was wondering would that be big enough for the two subs. maybe i can even try a single 15 in the hds315. at the end of the day im trying to get as loud on 800-1200 watts as possible while also fitting easily in my trunk. Any help would be appreciated thanks 97 Lexus ES 300 Source: clarion cs702 Front stage: faital pro 6fe200, seas prestige 27tafnc/g Subs: soundqubed hds212 x2 Amp: mids and highs PPI P900.4. subs Alpine MRP-M850
SubaruBass Posted March 20, 2014 Report Posted March 20, 2014 i have a pair of HDS312s in a 4cf box that is tuned to 35hz. i am VERY happy with them but they do take a long break in time. the suspension in them is stiff as all hell. 1200w with a pair of 312s would be very underpowered. i went from 1200 to 2500w RMS to feed them. so far i would say i am only giving them around 1700 or so due to my stock low output alternator. if you want loud and proper power a single 312 or even 315 with 1200w would be healthy bass with minimal upgrades. for daily driving my current setup is overkill, go deaf quick!
Rich Schenk Posted March 20, 2014 Report Posted March 20, 2014 i would go with the 2 12s over just one. will have more cone area. but everything comes down to the box so it all depends on who builds it and how good of a design it is. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
bcbrassard Posted March 20, 2014 Report Posted March 20, 2014 I have a T1D212 over powered on a T1500 in to highly tuned box(47hz) and trunk space is a problem for my car so i ordered 2 HDS310s and plan on building a proper box to house them. On the T1500 in 1 ohm they will see close to 900 watts each and hope for better substage than i have now. 2 12s or 1 15 for you would work well, its just all in the box design, power and what your goals are. Good luck
Benjamin Amparo Posted March 21, 2014 Author Report Posted March 21, 2014 im leaning towards 2 12s im just concerned about the box size. will 36x16x24 max be enough for that 4 cu ft i will need, and as far as tuning goes, i listen to absolutely no decaf what so ever, just not my thing. mostly listen to hip hop, rock, and spanish music so i would assume it doesnt need to be tune crazy low. anyways will my dimensions work, and can anyone show me a basic design with those dimensions max. by the way its a daily driver, will only be seeing 800-1200 rms 97 Lexus ES 300 Source: clarion cs702 Front stage: faital pro 6fe200, seas prestige 27tafnc/g Subs: soundqubed hds212 x2 Amp: mids and highs PPI P900.4. subs Alpine MRP-M850
Joe X Posted March 21, 2014 Report Posted March 21, 2014 A bit tight but still doable, power: around rated:
DubNDodge Posted March 21, 2014 Report Posted March 21, 2014 i have a pair of HDS312s in a 4cf box that is tuned to 35hz. i am VERY happy with them but they do take a long break in time. the suspension in them is stiff as all hell. 1200w with a pair of 312s would be very underpowered. i went from 1200 to 2500w RMS to feed them. so far i would say i am only giving them around 1700 or so due to my stock low output alternator. if you want loud and proper power a single 312 or even 315 with 1200w would be healthy bass with minimal upgrades. for daily driving my current setup is overkill, go deaf quick! SQ will be stiff for life. I had a pair for a year that never got "soft". It's their nature '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Benjamin Amparo Posted March 21, 2014 Author Report Posted March 21, 2014 @joe X thanks alot for the design, i think that will work 97 Lexus ES 300 Source: clarion cs702 Front stage: faital pro 6fe200, seas prestige 27tafnc/g Subs: soundqubed hds212 x2 Amp: mids and highs PPI P900.4. subs Alpine MRP-M850
