higher flow injectors on stock engine
thats the problem, i'm having issue finding the injectors i need, i bought these not realising they were for the 4.7 stroker
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
here's another question, can i take the 4 hole tips and put them on my 1 hole injectors?, thats all i really need to do
edit: nvm i thought they came out like the filters
2000 jeep cherokee 4.0 inline 6, i need 6 784 4 hole injectors, from a 00-01 neon or other dodge vehicles
Higher flow injectors mean DICK without higher flow air. And your fuel pump is probably delivering 65% max of what it's cable of. And injectors are probably running 70% of capability unless they are clogged. The Jeep PCM's were junk from 96-2004. You could be chasing CEL lights forever. Hit up a Jeep forum. I have been down this road.
What are you actually trying to do. ...... if getting more fuel into the engine is it. ... you must also be able to get in more air. .. more spark. . More timing as well as more tuning. Just adding more fuel. .. well trying to will do nothing.
2012 Toyota 4Runner Trail Edition-Singer 240A Alt, Odyssey Battery,Pioneer AVH-2550NEX head-unit, Pioneer GM-DX874 powering Kicker CSS67 front-CSC5 rear, and Memphis PR 1.1000 powering 12in SSA ICON in G.P. ported box.
2003 Tahoe-320A Alt, Odyssey Batt,2 Resilient Sounds Gold 15's sealed powered by Crescendo BC2000D, Turbulent Designs Ported box AVH601EX head unit and Pioneer 3ways in all doors.
