setting gains of t2500-BdCP
Skax
so when setting the gains with my DD-1 i was told to keep sub level at 0 and all headunit eq's at 0 and was wonder why not to leave it at what i listen to it at since when it finds the distorted signal of flat settings when i bumped them back up after tuning wouldnt it produce a nasty signal? just curious wasnt to sure about this so i thought id ask , rather be safe then sorry :) thanks guys !
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Follow the instructions bro.
will do :P just wanted to be more safe than sorry thanks KyLar :D
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
:good:
Let me know if you have any questions.
Read and follow the instructions to the letter. Peice of cake.
will do man, thanks for the help you've been giving :D
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Sub level shouldn't be at 0 I thought. You need to DD-1 where you max sub level is and set your amp to that level.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
thats what i was thinking haha but ill do it how the manual says i guess and hope for the best :o?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
1. This procedure will determine where the
maximum unclipped volume setting of the
headunit is. This is accomplished by setting the
bass, treble, ect, to zero; and any EQs and
crossovers in the headunit to flat. Later, when
you set the amplifier gain(s); you can reset these
to where you feel the customer will set them, or
where you will set them for your own system.
this seems to suggest that you should set the gains twice???
No, that says to set all the crossover and EQs to flat then set your HU.
Then when you are setting the gains on your amp you can set those back to what you want.
F150:
Stock :(
Processor: DSR1
  • Who's Online   0 Members, 0 Anonymous, 835 Guests (See full list)
