budget battery for 2500bdcp?
ok well i just got my 2500bdcp back and got it wired up and all yesterday im on stock batt and alt obviously the battery on the amp redlines on bass drops :D was wondering which battery/batteries would be good to through under the hood and in the trunk for now that would help and staying within a nice budget any ideas? , thanks in advance really appreciate your help guys
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Whats a nice budget ?
wanna keep it under 300 if at all possible since i having to redo my beaver panels the shop fucked me over on
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
first of all do you have the big 3 done, THAT IS A MUST with a 2500 bdcp
and secondly whats your power/ground wire like
1 run 2 runs?
ofc/cca?
get a xs power xp 3000 or d 31000 ( used off fourms or classifieds some where if need be for budget )for the rear and save to replace the front eventually
1 run 2 runs?
ofc/cca?
ill do some research for some used batts for a good price ill get back
na i dont have the big 3 done i was ganna order some more ofc 1/0 when it gets back in stock and some lugs and make my own instead of buying a kit. run from battery to cap is 1/0 cca though
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
1 run 2 runs?
ofc/cca?
yea i guess that sounds like a plan ill do big 3 then save up for the 3100 then do my panels last need to knock some electrical out of the way
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Also whats the front batt resting at ?
no idea i havent tested it yet
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Get your electrical in order before you install your amp man or your gonna break it before you really get to use it!
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
