I'm planning on getting 6 12' subs, each rated at 600 RMS and 1200 peak, can someone help me with how I would wire these together for maximum power and what would be the best amp for this, that won't break the bank. PLEASE HELP!
You will need to upgrade your car's electrical system in order for you to do that safely. This will add another 600-800 dollars to your current budget.
Eclipse cd7000
6 subs? I would say best to use 3 bass amps to push them 1 for each pair..thats the easiest way because with 6 subs all in parallel or series w no matter whether theyre svc or dvc 2ohm or 4ohm..youll get a wierd ass impedance and some amps will be stable at that and some wont. So either do 3 amps and get 4ohm dvc subs and wire in parallel or get 4 subs 2ohm dvc at 800w rms rating and wire them all together to get 1 ohm... heres what I would do if I had that much space. Get 4 15" subs and wire to 1 ohm on one amp.
Ps that many subs will always break the bank..think about the subs then the amp(s) then the highs youll need to keep up with the bass ..then all of the wire youll need cuz with this much shit you cnt go cheap budget on wire..and then on top of that all the electrical upgrades youll need..h/o alt ..batteries ( at least agm under the hood and minimum 1 in the trunk) big 3 .. DO NOT ATTEMPT THIS INSTALL WITH OUT ELECTRICAL UPGRADE!! YOU WILL BURN SOME EQUIPMENT THEN YOULL BURN MONEY REPLACING IT
You need trunk space to get groceries and shit...bitches love groceries
I vote 3 amps 6 subs 4 ohm DVC all wired parallel with a 1 ohm load and Strap the amps! That's what I would do anyways
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
You got so many options. You need to figure out what you want to achieve out of your system...
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
you dont even know how much space he has. for all we know he is trying to put 6 12's in the trunk.
im sure you just confused the absolute shit out of him though with your post....way too much cluttered information
  • Who's Online   0 Members, 0 Anonymous, 2606 Guests (See full list)
