FINALY GOING TO GET AN ALT BUT NEED HELP
After this weekend I will finally be able to buy my ho alt im thinking in the two fifty amp range.(want to run about 4k)
Can I hook up my new alt right away with just a yellow top under the hood. Will it charge to much I guess is what I'm trying to ask. Don't worry I'm doing big three in zero also.
I got a DC 270XP, ran a crescendo 3.5k on stock battery. Couldn't play at idle without dipping, but it didn't really drop when I was driving/revving
No it won't charge too much. The only way the alt would overcharge your battery is if you have an adjustable voltage module that you set too high. But amperage wise, the car/battery will only pull as many amps from the alt as it needs.
This.
It's the voltage that will cook things. You will be fine. Just bolt it on and plug it in.
alt will only output as much as the accessories in the car demand
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
