elgrande Posted April 15, 2014 Report Posted April 15, 2014 can anybody help me with some box dimensions for two kicker l3 15? my dimensions are maxed at I want it tuned around 34hz H:20 W:19 L:45
john253a Posted April 16, 2014 Report Posted April 16, 2014 Build to your max 20x19x45 In 3/4" And drop 3x 6" psp aero port 17" long You'll be a tad higher then the 34hz you want But the extra net will lower -3 allowing you to still play as low and maintain a good port volume
john253a Posted April 17, 2014 Report Posted April 17, 2014 can anybody help me with some box dimensions for two kicker l3 15? my dimensions are maxed at I want it tuned around 34hz H:20 W:19 L:45 No Build ^ this With 3off 6" aero ports (psp sell them 17" long) All in 3/4" mdf
elgrande Posted April 17, 2014 Author Report Posted April 17, 2014 Ok thanks ill look into it and wich way would the ports face to the side or the same as the speakers?
elgrande Posted April 17, 2014 Author Report Posted April 17, 2014 its a ford f150 2004 the box is going on top of the back seats
john253a Posted April 17, 2014 Report Posted April 17, 2014 its a ford f150 2004 the box is going on top of the back seats how do you plane to strap it down, just remove the rear seat, and put it back in when you need to a box that size won't be easy to take in out if thats the plane
elgrande Posted April 17, 2014 Author Report Posted April 17, 2014 Yeah i know it wont be easy. And i cant take the seats out
elgrande Posted April 17, 2014 Author Report Posted April 17, 2014 Ok lets say i took out the seats and made a big box like for example using the following dimensions and tune it to 34hz will it work or is it to much for the subs?? H:21 L:41 W:23.5
