8 10s Walled, 2008 Saab 93 - Loudest Saab
Hdc's have direct leads no? I'm not sure if they would be long enough to reach the back of the box, or sides depending on how you are wiring everything. So either way you might need to make an extension on them for them to reach. But I would say bolts are the easiest route. Maybe find some allthread and then use a washer/wingnut on either side of the wall. Unless you really feel the need to torque everything down 50ftlbs.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
im going to have so many bolts LOL
Have you figured out what amp(s) you are running? I bet you wouldn't need 16, but then again that would make trouble shooting much easier if you are having any issues.
What are you planning on doing anyways? 4 subs an amp at .5ohm or strapping both amps at 1 ohm?
Good thing the AQ hdc3's share the same dims as 9500i's incase something ever does happen. You will be covered and you will get an upgrade.
Wonder how long their shipping time will be?
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
