New to the SQ game
crw092782
Sounds like a good sounding system build ... But sorry to say, not Sound Quality (Yes, there is a diference) ...
First thing I would be seeking out would be a great pair of components for the front stage and work with tweeter positioning.
I know what SQ means. I was just saying that part of me would rather go to a more SPL build given the low cost of the subs. I am still checking in to component sets for the front. I just realized that I have 5.25's in the rear though. Makes my ocd kick in knowing they are not the same size front and back. lol I will probably swing back and forth 20 times before I order anything. It's what I do) Hearing a nice SQ setup is enough to make me want to build one of my own.
2004 Pontiac Vibe Build
Sony MEX-N5000BT
JBL P660C x 2
Sundown Audio Zv4 18
Crescendo BC2000D
Crescendo S800/4
Execution Audio 0 AWG Wire
Sky High Car Audio RCA's
Toolmaker Terminals
XS Power D1200
DC Power 240HP Alternator
Viper 5706
In the long run, a true SQ vehicle can equate to being cheaper than a number chasing SPL vehicle.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Not to mention a lot better on gas mileage lol
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
Absolutely
Unless you have to change out your rears because of head unit swap, I'd leave them alone on radio power and concentrate on the Front stage and image ... They should work great as is giving you that rear ambience effect.
also better usage life of the vehicle. Most SPL vehicles have to be rebuilt every so often ...
I've always been curious about that train of thought. Wouldn't you distort off the head unit power before the rca's output distorts to the amps?
2010 Mazda 3s 2.5L
Knu OFC 1/0
Not sure what you are getting at brother ?? Are you asking if you can use the radio outputs and RCA oouputs at the same time ??
Not sure what you are getting at brother ?? Are you asking if you can use the radio outputs and RCA outputs at the same time ??
Sorry I think I was mashing two concepts together. I know you can use speaker outputs and RCA outputs at the same time. I guess my question is wouldn't you clip from head unit power before rca's run through an amp because of the RCA's having a higher clip/distortion point.
I have seen it suggested quite a few times to run the rears off an aftermarket head units speaker outputs. Then you would use the RCA out's from the aftermarket head unit to bi-amp some components or run all 4 channels of an amp up front.
2010 Mazda 3s 2.5L
Knu OFC 1/0
Mainly depends on the characteristics of the headunit used in the application ...
some you can ... some you can't.
With this being my daily driver I am going to do it in stages. I ordered all of my deadener last night so I should have 50 sq ft delivered tomorrow. Once I get everything in, I am going to focus on a nice set of components up front for now. I figure it would be best to drop them in the factory locations for now, and then fiberglass a second set on the pillars later. I want to do it in sections to keep initial costs down, but so I can also hear the difference between each step. i.e. adding a 4-channel amp vs using head unit power.
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
  • Who's Online   1 Member, 0 Anonymous, 1936 Guests (See full list)
