need help with a box
gally
So i built a couple of boxes for my GZNW 15SPL---it turned out that it did not play as i wanted...sounds horrible...
subs specs
:Ground Zero Nuclear 15SPL (the yellow sub)
Model
GZNW 15SPL
Diameter
38 cm / 15"
Mounting diameter
360 mm / 14.3"
Mounting depth
255 mm / 10.04"
Voice coil
75 mm Flachdraht / 3" Flat wire
Cone
Paper-glassiber-kevlar
Power Handling
6500 W SPL Power
Impedance
2 x 1 Ohm
SPL
91,7 dB
Xmax
50 mm / 2"
Fs
32.3 Hz
Qts
0.42
Vas
65 L / 2.3 cu.ft
what i want is if someone can help me with a box design
i speciffically want a Sub up and port bwlow(down) on the right side
max dimension are:
wide -- 80cm
high -- 48cm
deep -- 44cm
tuned at about 30-33hz
thanks in advance
gonna be powered by 2 dd m1b wired both at 2ohm
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
Post the specs of what u built
What car
Amp power
You know more info
its a hatchback an opel corsa c
amp power would be 2 dd m1bs both wired at 2ohm
dont have any more info as im writing you guys from a tablet
my pc is gone for a couple fof days as it burned its motherboard
anyone?
ok sorry for the late reply...found the difference...box was way off i i was using some shitty glue...and the L ported side came off and the wood panel ond the bottom came loose
so i built another box tuned to 34 and it sound way different..sub is also inverted and so far it plays....down to 26 and get louder on higher notes(but not always)
need to post a vid in a while
i also reinforced the box with sillicone inside and did not get the 45s in the corners...this time....
