dsmdan Posted April 26, 2014 Report Posted April 26, 2014 I'm thining about picking up 3 of these group 31's for part of my battery bank. Reason for buying is they are the cheapest group 31's that will match what I need. I need to use them along with 3 other group 31's with a buss bar system. Problem is these marine batt's have both threads and standard leaded terminals. The leaded terminals would get in the way with the buss bar's. So would it be ok to simply chop off the leaded terminals and file them smooth and just run the threaded posts? Thanks. Here's the batt's. They are $40 cheaper than any group 31 with just threaded posts that I can find. They are the same group 31 all made by east penn. http://www.samsclub.com/sams/duracell-agm-deep-cycle-marine-and-rv-battery-group-size-31dtmagm/prod3590232.ip?sprodId=prod3590232&_requestid=63644 -Dan Kasun 05' Dodge Ram 1500 QCSB Hemi Blow-thru build in progress. 2 RD HW18's, RD D9, 5 Deka 9a31's, 6th order blow-thru box, Eclipse 7200mkii HU, 140' Knu Kollossus wire. DC Power 270xp Alt, Etc.
wizart383 Posted April 26, 2014 Report Posted April 26, 2014 I don't see any problem doing that. How are you planning to cut the lead post? I would personally use a hand tool (hack saw) over an electric reciprocating saw less chance of creating excess heat and spark when cutting.
audiofanaticz Posted April 26, 2014 Report Posted April 26, 2014 my only real other concern is there being enough of a lead post left on the inside of the battery after you cut them flush that you can drill into and tap some threads.
dsmdan Posted April 26, 2014 Author Report Posted April 26, 2014 my only real other concern is there being enough of a lead post left on the inside of the battery after you cut them flush that you can drill into and tap some threads. I don't see any problem doing that. How are you planning to cut the lead post? I would personally use a hand tool (hack saw) over an electric reciprocating saw less chance of creating excess heat and spark when cutting. Yup, planned on using a hand hack saw and hand filing it smooth. my only real other concern is there being enough of a lead post left on the inside of the battery after you cut them flush that you can drill into and tap some threads. Did you read? These batts have both threaded posts and standard lead terminals. Cutting off the lead terminals would still leave the threaded posts. -Dan Kasun 05' Dodge Ram 1500 QCSB Hemi Blow-thru build in progress. 2 RD HW18's, RD D9, 5 Deka 9a31's, 6th order blow-thru box, Eclipse 7200mkii HU, 140' Knu Kollossus wire. DC Power 270xp Alt, Etc.
Jessica Posted April 26, 2014 Report Posted April 26, 2014 dont forget about lead poisoning. wear a dust mask or something. Don't want you getting drain bamage and going bat shit crazy. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
truthsayer Posted April 26, 2014 Report Posted April 26, 2014 Have you attempted to unscrew the post? While it may be rare and unusual, i have seen where some will unscrew. truthsayer
Mr DeeBeez Posted April 26, 2014 Report Posted April 26, 2014 my kinetic has crew on posts Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2)
SnowDrifter Posted April 26, 2014 Report Posted April 26, 2014 My concern with this would be the lead near the cut distorting and breaking the seal against the battery ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Swordlordboy1234 Posted April 26, 2014 Report Posted April 26, 2014 A buddy did that exact thing. Don't break the seal and protect vs lead. Works great My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
dsmdan Posted April 26, 2014 Author Report Posted April 26, 2014 A buddy did that exact thing. Don't break the seal and protect vs lead. Works great Great, thanks for the input! -Dan Kasun 05' Dodge Ram 1500 QCSB Hemi Blow-thru build in progress. 2 RD HW18's, RD D9, 5 Deka 9a31's, 6th order blow-thru box, Eclipse 7200mkii HU, 140' Knu Kollossus wire. DC Power 270xp Alt, Etc.
