Should I upgrade Electrical???
Cj Kumz
Hey people. Okey I need some advice. I wanna know if I should upgrade as stated above and to what extent to get the most out of my setup.. I am powering a DD9515 (2 x 1 ohm) with a Sundown saz-3500d set @ 2ohms. It is in a 5.5 cubic foot box tuned to 38hz with a 10 inch pvc port. I am driving a VW Polo which came with stock 4 gauge wiring from the stock 90A alternator to battery and stuff. I am also using a 4 gauge power cable with an 80 amp fuse on it. Oh and a big non-maintenance battery. Now question is how far can I upgrade without having to change my alternator to get full potential of my setup.. Help me!!
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
Like it was said in your other thread. Upgrade to 1/0 do the big 3, and put an AGM battery under the hood and an extra one in the back.
Oho ok thanks a lot. I already have an AGM Battery infront so will just have to get one for the back and do the upgrade. Hey do you think my alternator will have stress charging both batteries at once??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
Well for starters, before you worry about upgrading your alternator or even thinking of doing so, you should get a quality piece of ofc 1/0 power cable to run your saz-3500 before you blow it to shreds and back using an amp that can potential pull over 350 amps of current through the 4gauge wire your currently using. Dont matter if your only running the amp at 2 ohms or not, your ghetto rigging high price gear together to make it work and that's just not right.
It should be ok as long as you put them in charged and put them on a charger frequently so they stay healthy
X2
New build coming........
YouTube:http://www.youtube.c...6?feature=guide
Old Build Log: http://www.stevemead...d-on-the-cheap/
Old Screen name: Redrebel66
Ok thanks a lot for the info. So tell me something, will the amp be able to still receive 350amps with a stock 90 amp alternator and the two batteries even with the 0 gauge??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
you are half right and yet so wrong,
yes that amp can pull 350a but no way is that ever going to happen at 2ohm
if you buy a 10k@ 1ohm amp and run it a 4ohm, does it require the elec of of a 10k amp or a 3k draw
bevcause
2x h/o alts, 6x runs of 0g to amp 2x run front to back and 4 extra batts as a min, for a 10,000rms 1000amp draw
witch isn't required for 300a of current draw
3k only requires 1x h/o alt 1x 0grun to amp 1x 0g run front to back and 1 extra batt
in the end he max current draw is restricted to 1.8-2k rms
all he need is an elec system to support 200amp
witch 0g occ cable can do (ofc not needed but is recommend)
1 extra batt in rear
0g big 3
bigger alt (not necessary to be a h/o 240a+ just bigger then 90a you have now)
bevcause
0g big 3
Great info bro. You have opened up my eyes properly now :) So just based on a ruff estimate, what amps would I be able to get with all that done bt without the h/o alternator???
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
Have you even checked your voltage drop at the amp?
switch all your wiring to 0gauge ofc being the better choice hands down.
do big 3 in 0gauge
1. Alt + to battery +
2. Alt case to frame or battery -
3. Battery - to frame
check voltage at amp again. If dropping below 12.5-12.8 (some people don't mind dropping down to battery voltage personally I would say try to keep it above 13v) then get an ho alt or battery for the rear. Ho alt being better.
what batt do you have up front? Like brand and size
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
do big 3 in 0gauge
It's a Hi-fase battery and the size is 640. Not too sure the mA, It is a big non-maintenance battery though. Ok so where do I connect the multimeter to check voltage drop?? And how can I test how many amps the battery is??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
  • Who's Online   0 Members, 0 Anonymous, 653 Guests (See full list)
