XS Power
If a DC Power 270xp is the largest alternator you can fit under the hood. D3400 Up front.
What would you recommend to run as a battery bank in the trunk for 10k rms?
Editted typos
Edited by cgrez33
Current Build:
1999 Tahoe #ComingSoon
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
DC power alternator you mean?
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Depends on the vehicle but I think a good start would be 5 batts. Biggest you can get to fit in what ever area you have. Do some voltage drop tests then add more if needed.
2 runs 2/0gauge or 4 runs 0 gauge min and in this case it might be more beneficial to do ground runs but if I was you I would do frame grounds and runs.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
If your budget allows four D3100s. If it doesn't, then two and monitor your voltage
Possibly, you didn't mention vehicle ( some are known for low charging voltage) or wiring. Also need to make sure your not clipping because it can create more heat which is bad for electrical.
if you go for it watch voltage drop and just make sure you top your batteries off ad much as possible.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Im at ~8k total....
270a Alt, 3 D3100's, and 1 S3400, voltage full tilt is about 12.0v flat.
I would suggest 4 D3100's in the back, but more so, dual alts or a bigger one like a 370.
I think the 270 and four D3100s would really be manageable, but like Chevy said more alternator would be nice. What's your budget, that's the best way to find a suitable option.
Maybe dual 270s and two D3100s
I have a Pontiac G6 Gt. Like I said I currently HAVE a DC270xp d3400 and 4 d3100's. I was curious about this because I really can't fit anymore batteries and want to stay in the trunk. So I was curious to see what I can get with what I got. I really doubt I can fit another 270 under the hood.
Current Build:
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
