FocusOn20s Posted May 4, 2014 Report Posted May 4, 2014 Just upgrade your battery under the hood to an AGM and you should be fine ftfy!
boom50cal Posted May 5, 2014 Report Posted May 5, 2014 Whatever the largest battery you can fit under your hood along with big 3 in 1/0 wire. If voltage issues still pertain(dropping below 12.8v very quickly) then another battery should be added to the rear. Assuming you can fit a d3400 under the hood, if you MUST, something like a D925 in the rear would be great. But since this hobby can quickly become an obsession, and nothing stays small forever, it may be worth upgrading to say an XP2000 or adding another D3400 in the rear. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
jarrius Posted May 5, 2014 Report Posted May 5, 2014 Just upgrade your battery under the hood to an AGM and you should be fineftfy!? 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Aj11 Posted May 5, 2014 Report Posted May 5, 2014 the clipping light is actually pretty far off from the dd1. if i turn it up to the clipping light i stay in the 13 range. if i turn it to the dd1 distortion i drop to the 11s ... I'm working on that tho! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
FocusOn20s Posted May 5, 2014 Report Posted May 5, 2014 the clipping light is actually pretty far off from the dd1. if i turn it up to the clipping light i stay in the 13 range. if i turn it to the dd1 distortion i drop to the 11s ... I'm working on that tho! hmmmm now I want to tune it with a DD1 lol. My 4 gauge run is only ~14ft so it's not too bad. The 4 gauge is rated for 150a up to 20ft. Amp never gets warm or anything. Shit bangs my temp XFL nicely. Im sure when I get my 0 gauge wire installed, it'll really wake up
Aj11 Posted May 6, 2014 Report Posted May 6, 2014 it will have a slight increase in power from the wire. but the difference between the clip light and the dd1 (on my deck) is +3 volume difference. clip light.comes on at 39 dd1 is set at 42 so 43 is distortion on the dd1. at the dd1 setting the clip light is on allot. but istill usually don't let it clip. mostly bbecause i like to keep the voltage up. if your voltage is low your gain setting changes and you can still clip so... better safe then sorry! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
FocusOn20s Posted May 6, 2014 Report Posted May 6, 2014 it will have a slight increase in power from the wire. but the difference between the clip light and the dd1 (on my deck) is +3 volume difference. clip light.comes on at 39 dd1 is set at 42 so 43 is distortion on the dd1. at the dd1 setting the clip light is on allot. but istill usually don't let it clip. mostly bbecause i like to keep the voltage up. if your voltage is low your gain setting changes and you can still clip so... better safe then sorry! well my headunit doesn't distort lmfao Factory headunit. 35/35. When I used a friends DD1, it didn't pick up distortion when using it on the headunit. I set the volume at 30 and use that as the max undistorted position.
noobslayer77 Posted May 6, 2014 Report Posted May 6, 2014 do a big 3 and use a d3400 under the hood if it fits. u can also use the battery calculator on the XS website, or contact Nate. He's very helpful. Just give them a call or shoot him a PM. 2004 Jeep Liberty Limited 2 13w7s skar 3500 cnf mids (soon) xs batteries
Aidan Hansen Posted May 6, 2014 Report Posted May 6, 2014 You'd be fine with a D3400 and big 3. This tool is very helpful for what you're looking for:http://www.xplicitaudio.com/electrical-systems/ ^Vehicle log to come soon for this.^
