Tuned in. Good work so far
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
What work? I haven't seen a picture yet.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
you WILL need a HO alt for that ct sounds 3000.
0 gauge. not 1 gauge. 1/0 or 0 gauge. 1 gauge is smaller.
you may be able to get away with a single secondary d3100, along with an upgraded xs under the hood. depends on voltage.
there shouldn't be a piece of 4 gauge in the whole build, unless you're wiring up mids and highs amps lol.
this
and excited to see this maybe i can hear it lol
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
shit posted in the wrong thread. Tuned into this one too lol
Team Subsonic Lows
Listen to these guys ^^^ they know what they are talking about.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
3k rms will pull 200+ amps on music and can pull double that on test tones.
title says 4000 watt build, your looking at 250-300amps of power draw on music roughly. Not including what the car wants/needs.
for that I would look into a 200+ amp alt, eld bypass for sure, 0gauge big 3, 2 runs 0 gauge pos front to back (neg runs if you want). Then a good upgraded stock batt and an extra bigger Bart or 2 smaller ones.
can get away with one 0gauge pos run but I would do 2 for piece of mind. The smaller the alt the more batts you need and the less play time you will get before dropping voltage becomes an issue.
your off to a great start so just keep at it and dint take short cuts. Short cuts only create bottle necks in your system which can create less then expected results or worse case would be a fire hazard. Might take longer to get your electrical right due to saving money but its worth it in order to get the results you want plus safety.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Ive made my mind up on speakers and subs and deadner
2 pairs of audiocube 6.5 componet sets only 100 dollers each
1 pair of their super tweeters
2 hdc3 12s
40 square feet of deadner the green and black stuff
will 40 feet be enough for my whole car?
Gonna run the subs at 2ohms
for electrical im gonna do the eld bypass
upgraded battery under hoodf
and extra battery in trunk
Im going to go with the dc 180 amp alt
Charges at 14.9 and does 130 amps at idle
