Popwarhomie Posted May 8, 2014 Report Posted May 8, 2014 Throw a 300 on each run. 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build.
CleanSierra Posted May 8, 2014 Report Posted May 8, 2014 I got a fifty foot roll of sky high ofc That wire is rated at 350A over a 20' run. Fuse each wire(if within that range) at 350A. Im not the one you want to try to troll. Just a fyi for you.
Kyblack76 Posted May 8, 2014 Report Posted May 8, 2014 Now if you are doing duals on the amp i WOULD NOT DO 2 AT 350.... split it SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
CleanSierra Posted May 8, 2014 Report Posted May 8, 2014 Now if you are doing duals on the amp i WOULD NOT DO 2 AT 350.... split it .I didn't think of that, it bottlenecks down to single anyways. Half would work, sorry for brain fart. Im not the one you want to try to troll. Just a fyi for you.
Kyblack76 Posted May 8, 2014 Report Posted May 8, 2014 I think thats why some burn.... Yes you rate for wire.. AT TIMES.. Lets say put a 2/0 wire to a 1500 watt amp. Would you fuse to the wire or ASKING in that case? That make sense? Fusing to THE WIRE, is not ALWAYS the rule. Not if your UBER over SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted May 8, 2014 Report Posted May 8, 2014 I have a 80 amp stock alt. I add a 1/0 run. 300 amp right? If you added a 300 amp fuse to it in line, it would NEVER break, until the WIRE and some of the car burnt....... Anyone with me here? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
CleanSierra Posted May 8, 2014 Report Posted May 8, 2014 I'm with you captain, sloppy kisses Im not the one you want to try to troll. Just a fyi for you.
Kyblack76 Posted May 8, 2014 Report Posted May 8, 2014 I'm with you captain, sloppy kisses send my your drawers.... NOW SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Aj11 Posted May 8, 2014 Report Posted May 8, 2014 so i was told here that my bat + to alt + shouldbe dfused for the wire not the alt. it's 0g about 2ft long. it's a 120amp alt. so your saying i should put ike a 150anl fuse to it not the 250 i have now right? i have all these sizes which one is best (doubles and trips of most) 100 125 150 175 200 250 275 300 325 350 jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
