mjdonahue23 Posted May 7, 2014 Report Posted May 7, 2014 hey guys just wondering dose any one know the specs to the stock Bose amp is in an 03 Tahoe and can i put different speakers in and still use the Bose amp? 1995 geo prizm lsi 2003 chevy tahoe2 sound qubed HDS34 tuned @ 25hrzs dxspower d1200pioneer deh-x9500bhs<p>130db
youngbass98 Posted May 7, 2014 Report Posted May 7, 2014 Yeah you can just hook up new speakers to the stock wires just make sure it is they are the same impedance 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
mjdonahue23 Posted May 7, 2014 Author Report Posted May 7, 2014 what is the omhs of the bose amp 1995 geo prizm lsi 2003 chevy tahoe2 sound qubed HDS34 tuned @ 25hrzs dxspower d1200pioneer deh-x9500bhs<p>130db
bigmizzle99 Posted May 7, 2014 Report Posted May 7, 2014 Bose speakers are typically 2ohm. Just get 2ohm speakers for replacement Camaro SS Build Altima build 2.0 Altima build 1.0
AA98hoe Posted May 7, 2014 Report Posted May 7, 2014 Bypass amp TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
hazestorm23 Posted May 7, 2014 Report Posted May 7, 2014 Bose speakers are typically 2ohm. Just get 2ohm speakers for replacement not always true they sometimes can change it. Look it up before you start replacing speakers and possibly damage the amp. As I have had problems with the Bose and monsoon systems in cars having different impedance ratings
AA98hoe Posted May 8, 2014 Report Posted May 8, 2014 Amp should be behind glove box they make a bypass loop harness simple plug an play TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Aidan Hansen Posted May 8, 2014 Report Posted May 8, 2014 I'd avoid using the stock amp. If you mess up somewhere it's a helluva time figuring out the problem. I've swapped out speakers in my previous escalade no problem but it just isn't very simple in case you want to go back to stock when you go to sell the vehicle for instance. ^Vehicle log to come soon for this.^
islandpride684 Posted May 8, 2014 Report Posted May 8, 2014 Below are the specs for Bose w/onstar 4 ohm 6.5 fronts 8 ohm 6.5 rears 2 ohm rear sub If you need the wire diagram lmk... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
mjdonahue23 Posted May 8, 2014 Author Report Posted May 8, 2014 ya i just got this tahoe 1 week ago and the driver side mid is blow en and i just need to replace it but any suggestions on replacement speakers? and should i just fine a oem Bose speaker and just replace it ? 1995 geo prizm lsi 2003 chevy tahoe2 sound qubed HDS34 tuned @ 25hrzs dxspower d1200pioneer deh-x9500bhs<p>130db
