hey guys just wondering dose any one know the specs to the stock Bose amp is in an 03 Tahoe and can i put different speakers in and still use the Bose amp?
1995 geo prizm lsi 2003 chevy tahoe2 sound qubed HDS34 tuned @ 25hrzs dxspower d1200pioneer deh-x9500bhs<p>130db
Yeah you can just hook up new speakers to the stock wires just make sure it is they are the same impedance
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
Bypass amp
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Bose speakers are typically 2ohm. Just get 2ohm speakers for replacement
not always true they sometimes can change it. Look it up before you start replacing speakers and possibly damage the amp. As I have had problems with the Bose and monsoon systems in cars having different impedance ratings
Amp should be behind glove box they make a bypass loop harness simple plug an play
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I'd avoid using the stock amp. If you mess up somewhere it's a helluva time figuring out the problem. I've swapped out speakers in my previous escalade no problem but it just isn't very simple in case you want to go back to stock when you go to sell the vehicle for instance.
Chevelle%20Team%20Cover%20without%20RE%2
^Vehicle log to come soon for this.^
ya i just got this tahoe 1 week ago and the driver side mid is blow en and i just need to replace it but any suggestions on replacement speakers? and should i just fine a oem Bose speaker and just replace it ?
  • Who's Online   0 Members, 0 Anonymous, 1694 Guests (See full list)
