Kyblack76 Posted May 8, 2014 Report Posted May 8, 2014 so it protects with ALL unplugged? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
ikillsuckers Posted May 8, 2014 Author Report Posted May 8, 2014 I just unplugged one tried it and if it went in to protect I plugged it back in and moved onto the next one and did the same thing until I went through all 4. should I unplug 1 leave it unplugged and move on to the next and do it that way? I did not try to unplug them all and see if it protects that way. let me do that
Kyblack76 Posted May 8, 2014 Report Posted May 8, 2014 Cool... unplug ALL, and see what happens... Also, your doing the speaker wires, not the rca's right? If she goes into protect, with no load...... im sorry. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted May 8, 2014 Report Posted May 8, 2014 If it stays on, put a channel in, and do the same..... keep adding UNTIL it goes south. Where it goes shit, thats your issue...... again, if it protects with no load.... then.... its new amp time..... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
ikillsuckers Posted May 8, 2014 Author Report Posted May 8, 2014 gotchya, ok thanks. hopefully its all good!! ill report back but probably be tomorrow.
ikillsuckers Posted May 9, 2014 Author Report Posted May 9, 2014 ok kylar I did what you said and figured out which speaker is causing the problem!! its left rear door that's causing it. haven't figured out why yet but I guess ill have to pull the door panel off and check it out, thanks again
tdsa23 Posted May 9, 2014 Report Posted May 9, 2014 You might have them all backwards pos to neg check your wiring make sure all of them are pos to pos neg to neg XS Power D5100, 2 D2700s, & 2 D975s MechMan 220a Alt DC 5K Kicker 650.4 2 12 Ascendant Audio Mayhem's Pioneer DEH-P7200HD Rockford Fosgate 3sity.1 Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899 https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
oldsoundguy Posted May 9, 2014 Report Posted May 9, 2014 ok kylar I did what you said and figured out which speaker is causing the problem!! its left rear door that's causing it. haven't figured out why yet but I guess ill have to pull the door panel off and check it out, thanks again Nice job finding the problem. I like it when someone gets advice and actually uses it and finds the problem with out arguing that they know everything. LOL 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
ikillsuckers Posted May 9, 2014 Author Report Posted May 9, 2014 thanks! ya it felt good to trouble shoot and figure out the cause of the amp going in to protect. and ya il have to check the wiring I just find it odd that it started happening two weeks after I installed them. im guessing either the wire got pinched somewhere since ive had my rear seat off since installing it or its touching metal or something? idk but we shall see!
