At what point does your amp put out its full rated RMS?
Ok, so I've been curious about this. Might be a stupid question, but say you have an amp rated at 1200w @ 2ohms. I know that with a meter you are just matching the gain on the amp to the output of the source(or something like that), so does the amp always put out 1200w once its on? Or do you increase the wattage as you turn up the head unit? Perhaps it is in direct correlation with gain? Just looking for some clarification, thanks guys
AQ3500.1
15" Fi SP4
1/0 Knuconceptz Power/Ground
1/0 Sky High Big 3 Upgrade
Pioneer AVH-4200NEX
XS Power D1200 Underhood
Intimidator Gel In Trunk
CES 250A Alternator
Easiest way to set this is with a DD-1. to get an actual wattage you would need an AD-1 or AMM-1.
One thing you also have to take into account when in a setup in a vehicle is your resistance. For instance, finding your amps power its putting out with the AMM-1 and knowing what ohm that power is being produced at gives you a idea on if you're putting out rated or not.
Chevelle%20Team%20Cover%20without%20RE%2
^Vehicle log to come soon for this.^
your amp can be going from 10w to 1600w In a few seconds. it depends on what ohm load it's seeing. not mention box rise. and rms isn't really what your amp pushes out (all the time) sings are constantly changing in hz and ohm load. like the Watts change so don't the ohm. your sub can go from 20ohms to 2 ohm back to 15 down to 3 in a second. a rms isnt really a real world way to judge what your amp is doing.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
This is why readings off a AMM-1 for me make more sense then a AD-1. I'm not a shop owner and therefore don't need to justify the AD-1 for my personal needs. The AMM-1 is justifiable because it will detect the power in my buddies or my own systems. If you're doing or close to rms while in a system you're doing good. If you're measuring off someone else's tests even with the same hardware as yours in their vehicle or the bench tests off the AD-1. You're seeing potential ratings, not what yours is doing specifically because every amp can be different in numbers slightly. Two models of the same amp and even from the same batch can have two different sets of peak numbers due to a few factors.
I might have had a few drinks before i posted this last night haha. Dont think it was that hard to get, just curious about this on a general level really. Looks like you guys answered my question, I just didnt know if you are always pushing full power or if it was based on your volume being turned up, in a nutshell.
I was really confused by the way he phrased his question lol.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
RMS measurement is a measure of "power density". It is 0.707 of Peak-To-Peak sine-wave readings so that the roughly 30% deducted can be used to fill "voids" in the sine-wave power envelope of a given sine-wave.
So what does RMS have to do with evaluating an amplifier's performance? Actually an RMS rating has very little meaning in terms of actual dynamic performance of an amplifier, although it has some value when comparing different amplifiers from different manufacturers. If all manufacturers quote their RMS values honestly it is possible to determine which machines are more powerful under RMS test conditions. Unfortunately many manufacturers can get very creative in their measurements, and so all RMS ratings have to be taken at less than face value just in case .......
To obtain an RMS rating, a given amplifier is placed in a test jig, attached to a fixed load of a specified impedance, and a signal at a given frequency is increasingly applied until the amplifier cannot produce any more power without "clipping" the sine-wave it is trying to produce. At this point a voltage reading is taken with an instrument calibrated to accurately indicate RMS voltage, or the waveform can be measured with a calibrated oscilloscope and a mathematical calculation is undertaken to convert its Peak-To-Peak reading to RMS. Using another mathematical formula, the voltage, in conjunction with the fixed load, produces the RMS rating.
What has been obtained is an indication of what power the amplifier can produce continuously at a given frequency, to a static, usually non-inductive load, connected to other test equipment. As the reader might already suspect, this test is far removed from any real-world practicality as far as reproducing music is concerned.
Dynamic Audio Power (DAP)
Dynamic Audio Power is just that. It is a measure of what an amplifier can do when placed in a situation where it is producing actual music, into a dynamic load (a loudspeaker). It is an estimate of how an amplifier can handle any number of frequencies simultaneously into a shifting impedance, as any loudspeaker can have a number of impedances depending on frequency applied. It is a measure of what reserve power is available to produce a smashing low bass note while at the same time some very subtle high frequency content. In short, it is a measure of what an amp can do in the real world, with real people listening to it, not how it can communicate with a lot of test equipment in a laboratory.
Dynamic Audio Power usually appears to be greater than RMS in any given amplifier, by a factor of two (twice as much). This is because the amplifier is not totally consumed trying to produce a static frequency continuously as in RMS, so that when a particularly short term heavy load is placed on it (lets say a powerful bass note), the amp has almost all its reserve at hand to do that job alone, and so can handle the momentary task with relative ease. This explains why amplifiers that are rated rather low in RMS terms have the ability to produce audio results way more than the low figures would tend to indicate.
So - which rating is more important? Actually both have their place in evaluating an amplifier. The RMS value can be a useful standard by which all manufactured amplifiers' power can be compared, if all manufacturers would only tell the truth, or test under exactly the same conditions. For instance any, poorly crafted amplifier may be able to produce sizable RMS wattage at 1000 Hz but do terribly at 30 Hz (where the wattage really counts), so the manufacturer will naturally quote the RMS at 1000 Hz. We always quote our RMS power ratings at about 30 Hz (unless otherwise stated), because if the power output is great there, it can only be even better everywhere else.
Dynamic Power is very useful because it predicts just what the listener will hear in real-world conditions. An amplifier is performing an amazing task, when trying to reproduce thousands of interacting waveforms, and their harmonics, while driving a loudspeaker that is in every sense of the word, a "moving target".
hear this should help and clear some things up for you. it doesn't answer your question exactly but it well help.
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
^nice post
OP, as others already have answered, the amp power ranges and increases in power as you turn up the hu. Keep in mind also, that for any particular amp, you have to have the electrical to back up the power. Just because an amp is rated at 5000 watts does not mean it will do it if you don't have the power and install so that it can do that number.
  • Who's Online   0 Members, 0 Anonymous, 1739 Guests (See full list)
