Lowest voltage you would run?
Show me a vid,..
Put a 200 amp fuse inline.
ANd GO APE SHIT..
Show me that you blow it..
hell .. put a 150 in.......
On a musical peak a fuse won't blow over it's rated, especially these fuses we use for CA, and I know you know that. But I'll do you one better than popping a fuse, here's a vid I shot a couple weeks ago. Voltage is off and low because I wired them in quick and used the same leads for both, but amperage is it's own run, it's where it should be.
Of course amperage draw is frequency dependent, and this song only goes into the mid-40's I think.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
LOL..
k
so you hang at 14v
and pull 200amp..
cool....
you win bra..
Lol. Not sure why you made this into an argument and are acting like that, I was simply adding my experience to the discussion. No need to get your panties in a bunch. Also, you are the KING of edits.
LOL..
k
so you hang at 14v
and pull 200amp..
cool....
you win bra..
EDIT
cool...
your the king of voltage...
EDIT
EDIT
says the guy that just did a edit
I don't drop under 13.6 revving, and I'm more than cool with that.
The lowest Id ever consider going is low 12s.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
LOL..
k
so you hang at 14v
and pull 200amp..
cool....
you win bra..
I see Kyle trying to prove a point, isn't that the same thing you're doing?
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
LOL..
k
so you hang at 14v
and pull 200amp..
cool....
you win bra..
ya... i may have been a penis...
but,.. .. im just saying.. ill put my FLUKE clamp over his ammeter all day..
Enough thread jack....
I apologize ...
A dc 5k will pull 400 plus amps at 1 ohm if pushed full tilt at clean power levels. I just put a clamp on a buddies dc 5k wired at 1 ohm the other day. the only way I can see you pulling 200 amps is if you were either wired at 2 ohms or your gains are not set properly to their potential.
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
