Right, I see your point, when thinking about it again, I kind of agree generally.
In your case I'm completely buying the reasoning. However, Im still not convinced that a cable needs close to stipulated max amperage to get hot. From vids I've seen no excessive amounts of current are required to over time (some 30mins I think it was) would still make a SIGNIFICANT difference to OFC wire even at (what I remember as: ) rather real-life experienced amperage.
This is perhaps a bigger problem in my eyes than in yours, since our market over here has flooded with low cost low quality CCA wire the last couple of years, even if prices is not more than about 30% less expensive than OFC still.
Some people are making a good deal out of low quality. Not enought people discuss material, but stick with what gauge the cable is.
Keep the good work up!
Cheers,
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
Was the time high full, half, quarter, or what in the tray you are taking about?
You have to remember that music time highs are a lot different than solid loads.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
  • 3 weeks later...
Havent been able to work on the hoe since the 19th had another install going on.
Sprayed a little foam last night, made a battery rack today and trimmed the foam i sprayed yesterday.
So not much of an update.
Edited by Audiofanaticz
Might want to check the engine then.
Sounds like it could be a problem if your that loud already.
